Results 1 to 15 of 20
    Default Tolerance 2009 2 Activation
    Hi Guys,
    I know the Automotive software has gone, I just need some help Activating my old copy of Tolerance data.
    Can anyone help?
    LD
    Quote Originally Posted by londondiagnostcs View Post
    Hi Guys,
    Can anyone help?
    LD
    Hi Guys,
    Can anyone help?
    LD
    hardware id post here and someone will answer you for sure.
    londondiagnostcs
    I answered you in pm
    I know this is of topic, but is there instructions for service reset and key programming in tolerance data, and how can I find them?
    Found at one forum the simple decision
    In reply to request of a code change initial 8 signs, and other all identical *****-***CD-CFCFC-6CDAB-38EC6
    For example: the inquiry a code 4C7F55B2 is changed under the table the first 8 signs
    It turns out B380A-A4DCD-CFCFC-6CDAB-38EC6
    request 0 1 2 3 4 5 6 7 8 9 A B C D E F
    answer F E D C B A 9 8 7 6 5 4 3 2 1 0
    D459F638
    2BA60-9C7CD-CFCFC-6CDAB-38EC6
    AC07E8A3
    53F81-75CCD-CFCFC-6CDAB-38EC6
    607D84B3
    9F827-B4CCD-CFCFC-6CDAB-38EC6
    F02889F5
    0FD77-60ACD-CFCFC-6CDAB-38EC6
    80642FF7
    7F9BD-008CD-CFCFC-6CDAB-38EC6
    90725B56
    6F8DA-4A9CD-CFCFC-6CDAB-38EC6
    F0434966
    0FBCB-699CD-CFCFC-6CDAB-38EC6
  7. The Following 4 Users Say Thank You to nier For This Useful Post:
    beepprog (6th December, 2021), goran13 (2nd December, 2020), m7md (18th February, 2018), radiodecoder23 (25th January, 2019)
    Ukraine
    Posting keygens is forbidden
    May 2009
    Belgrade
    I was changed something in system time and if I run TD2009 become message:
    The machine time has been changed!
    Please adjust the computer time..
    and then "Access to program reset"
    "enter unlock code for nnnnn"
    i haven't keygen for this 5 digit code (not work TD keygen, it need 8 digit).
    I know that is solution new installation, but if any have beter solution...Thanks
  10. #9
    May 2009
    Belgrade
    Nobody know?
  11. #10
    I HAVE TOL?RANCE DATA 2009 ACTIVED I LL SEND YOU
    MY SOSGARAGE@GMAIL.COM
  12. #11
    Top Poster drahtman's Avatar
    Oct 2010
    Europe
    I have the same problem and i cant installed TD2009.2 any more. Any one know what do i need to delete or change in the registry of Win7 64bit ? I dont know where to put the activation code. Maybe Win7 64bit is incopatible with TD2009.2 ? Any help or link here or PM appreciated.
    Best Regards,
    Drahtman
  13. #12
    Oct 2010
    Europe
    Tolerance data works on win7 64bit and i solved the problem. Works now. Thanks for all replays - just kidding.
    Best Regards,
    Drahtman
  14. #13
    May 2009
    Belgrade
    Quote Originally Posted by drahtman View Post
    Best Regards,
    Drahtman
    what ?? how ??
  15. The Following User Says Thank You to banetv For This Useful Post:
    dreamboxservice (5th June, 2022)
  16. #14
    Oct 2010
    Europe
    On Win7 64Bit you must go to the c:/ProgramData/Sls.ini and insert keycode generated with keygen. Look in the attached picture marked with red.
    Wish you all the best,
    Drahtman
  17. The Following User Says Thank You to drahtman For This Useful Post:
    harryt (22nd January, 2023)
  18. #15
    drahtman that doesn't work for me
