Page 21 of 22 FirstFirst ... 1116171819202122 LastLast
Results 301 to 315 of 324
Thread: Opcom 082010
  1. #301
    tiguan's Avatar
    Default Op_com..Help!! Firmare/Software
    Quote Originally Posted by mattydr67 View Post
    Go to settings andrun a Interface Test
    It will show your firmwear
    Good luck
    Someone has given a Op_Com without software CD, I do not know whether it is original or clon (I think Clon)
    Just downloaded drivers to check with OPComFUT
    which version is the version it is a Firmare version 1.20
    Can someone help with my version of what I need to update and software that I can best use it.
    it is the first time in my Op-Com to use....Please Help...
    Tiguan
  2. #302
    Feb 2012
    Hi to all,
    can anybody tell me how with op-com VECTRA C UEC-module (underhood electrical centre) program.
    Quelladresse UEC
    Ursprungs Adresse: 0x00000253
    Kennung: 0x0202
    Fahrgestell Nr.: W0L0Z**********
    System Name: UEC
    Teile Nr.:13170900
    Softwareversion Nr.: 000007D0
    Sys-Beschreibung: LEAR 0400
    Alpha Code: CS
    I get error message: 0x0202 ... please contact ADAKO
    with Astra H opcomclone works with all modules fine.
    Thanks a lot...
    EDIT:
    can i copy from new original opcom software (160212) file OP-COM\LangData\DE\CANVARCODING\CVECTRAUEC.0x0202 to clone software and run without consequence for UEC ??
    can i all the files responsible for module programming copy? replace old with new, without consequence?
    regards
  3. #303
    Feb 2012
    seems strange
  4. #304
    Feb 2012
    Quote Originally Posted by andyhh View Post
    seems strange
    in the 08_2010_clone_soft are no files responsible for program the UEC with driverID 0x202
  5. #305
    Apr 2012
    Probably is newest version for China clones?
    08.2010 can't enable Check control on my car...
  6. #306
    Apr 2012
    ITALIA
    I'm trying to update the diagnosis OPCOM opel cracked.
    Can you help me?.
  7. #307
    DK Veteran manocao's Avatar
    Default DOWNGRADE OPCOM FIRMWARE BACK TO 1.39
    Quote Originally Posted by manocao View Post
    with opcomloader you can try last 1.44 firmware with opcom 100219a and then go back to 1.39 if you like, no problem at all, of course if you have never started any 2011 official opcom version with interface plugged in computer (which would have upgraded to 1.43 or 1.44 but disabling bootloader) or some 2010 version which erased your interface's pic
    i found a program that is supposed to be able to downgrade opcom firmware to 1.39 EVEN if it was upgraded to 1.41 or 1.43 or 1.44 or 1.45 by means of 2011 2012 official opcom software
    no matter if you started some 2011 2012 official opcom version with interface plugged in computer, which would have upgraded to 1.43 or 1.44 but disabling bootloader
    2011 and 2012 official software versions of opcom dont erase pic of interface but disable bootloader
    ocflash doesnt work if you started some 2010 version with interface plugged in computer, which erased your interface's pic
    ocflash
    howto:
    1. connect opcom interface through usb only
    2. run ocflash
    3. click on "request interface" to check actual version programmed on interface
    4. if programmed version is 1.44 or 1.45 click "load firmware" and select fw139.hex from "Firmwarefiles" folder
    5. click "change"
    6. select "automatic mode" and click "flash"
    __________________
    China: OPEL Tech2 non-CAN multiplexer USB, OP-COM USB, OBDII Elm327 USB, VAG-COM 409.1/VCDS Lite 1.0 KKL USB
    Homemade: UNISCAN Visa 1.83 RS-232, Renault XR25PC USB, BMW KKL USB, Nissan Consult1 USB
  8. #308
    opcom ask me all time for an key how can i solve this?
    here is my id: AC80FB12-582127E6-0593FBD8-F2549393-C8E13E93
  9. #309
    Oct 2008
    On Earth
    Quote Originally Posted by RPM chiptuner View Post
    What version of OP-COm ask you this?
    It ask you for activating I suppose, am I right?
    Good luck
  10. #310
    Dec 2012
    GARAGE
    hi everyone! I use trik with de version and upgreade fw to 1.47. i quick test it on my astra h 2006 17cdti and works good I think it scan faster., nothing erse and clone scan all moduls.
  11. #311
    Dec 2012
    Quote Originally Posted by marmaro View Post
    What was the trick ??
    Best one I'm using at the minute v1.39 08 2010 thanks to certain members seems stable an quick enough tried on a vxr vectra c ,corsa c ,vectra b ,05 Astra h 1.7cdti
  12. #312
    Oct 2008
    On Earth
    That's right
    There's no trick and there's no high speed if you use other firmwear then that one you need for that version.
    OP-COM CHINA CLONE 08-2010 ( 100219a ) need firmwear 1.39
    Any other firmwear version you use will make some functions not working.
    Firmwear 1.47 it is good just in lastest versions of OPCOM as 121001a
    Other 2012 OP-COM/VauxCom versions still use firmwear 1.45
    Anyway for the one who want to dream we cannot stop them. So guys Keep Dreaming
    Good luck
  13. #313
    tiguan's Avatar
    what can I do about it, I can not read Opel Corsa-D 2007 / Opel-Astra
    I use Op-Com 082010 firmwear 1.39
    Need Help thanks
  14. #314
    Oct 2008
    On Earth
    Maybe you have a hardwear issues
    Or try with other computer or other tool
    Good luck
  15. #315
    Jan 2016
    Any news, about this year Opcom version?
