Results 1 to 13 of 13
    Sep 2010
    Naas
    Default opcom Programming failed !
    Hi, I have problem in vectra c to key programing. before I have erase all units inside (immo, ecu,...) and now when I try program new or old key always I have Programming failed ! on opcom (v1.39. 090821d-en).
    Im doing something wrong or can be opcom broken.
    Almost all 2009 cracked Op-com versions not programmed correctly ( some give error message , some said successful , but all failed to programmed )
    Use an old one ( which need serial number ) or use latest 100219:
    http://www.digital-kaos.co.uk/forums...2010-a-161300/
    Sep 2010
    Naas
    thanks , I try to use other software
    Sep 2010
    Naas
    ok, now I have problem. still cant program key and I erase all key from immo . cant start engine. What the procedure is to do synchro and program key from begin to make sure is correctly.
    Quote Originally Posted by msienicki View Post
    Depend on car , programming menu can be different
    If you succeed to erase mean software is working and security code is good
    Search for transponder key programming menu
    Depend of car , some immo could have programming menu and special option menu ( one is for erase key , another is for learn key )
    If you still not found , pm me and i will try to look myself
    Zagreb
    Try Opcom 090714 ver. software works fine for programming. Here is link for guide if you need it.
    http://opcomforum.yolasite.com/resou...er%20Guide.pdf
    Sep 2010
    Naas
    I found position in menu but problem is when I try program old key (in menu is program new and program old key) I have Programming failed ! (I try new is this same). I found in other place information about op-com clone . Sometimes is problem to program old key and better is use new transpondent. I have order new transponder today and try to program to car. I let you know.
    M8 , you have wrong program !
    In latest version of Op-com , i give you link already , there in no new transponder or old transponder menu !
    There is only Learn transponder menu
    Junior Member carevir's Avatar
    New key---needed new transponder
    New immo---needed new transponder
    Swap ecu---old transponder
    The problem is your software, op-90821d it does not work correctly
    Sep 2010
    Naas
    software??? 090714 this is the best software for test and this job???
    Mar 2013
    Does anyone know which version of Opcom can program old key to an Agila 2001 with immo 2 system?Key is recognised as old but learning fail .
    In opcom immobilliser guide you can see "Learn old key " option ,maybe this feature was removed in newer opcom version ?
    I know that tech2 can do it ,but I am interested to do it with opcom
    Aug 2011
    uk
    Never had problem with any opcom software clone or orig for programming key on Vectra C!
    Your doing something wrong, you've managed to erase keys so it's working! You have your vin in ecu etc...? And your DDM and PDM and REC, BCM CIM IPC and ECU all except the pin?
  13. #13
    Mar 2013
    I am talking about erasing and reprogramming an old key to the same car.In measuring blocks status was TP wrong key,
    but guess it was because ECM was not paired with immobilliser.
    Struggle to reset with carprog ,no luck till push Brute force reset ,ECM got immo pin ,paired succesfull ,client and car gone
