Can someone please upload SDP3 dongle Hasp Emulator? No one has?
this is a emulator for Hasp Hl protection, like Scania but i dont know how used.. maybe is necesary a one original usb key dump
gmzysq (13th May, 2016), putodaserra (29th December, 2016), tolisnancy (20th October, 2018)
hello
this emulator works on Windows Vista?
servr for any version of SDP3?
hello
this emulator works on Windows XP?
hi..
this emulator works on windows 7 ?
I make a dump from original usb key. I used two different programs. So there are two dumps. How do i emulate the usb key using these dumps?
I read that need to generate a REG file and a DNG file ... Anyone know how to generate?
jrjrjrjr / If you want to test your dump file I have SDP verison 1.17 1.21 2.32 2.50 2.52 all whitout usb key.
Hello.
Please tell me how to use the emulator?
This should be done by some one who has original dongle, and after that we all can use it.
http://rapidshare.com/files/64394078...-EDGE.rar.html
INSTALLATION INSTRUCTIONS
1. Unzip and Unrar.
2. Make sure you have the latest Sentinel dongle drivers installed.
3. To dump and solve make sure the original Sentinel key is connected
to a LPT or USB port then Run EDGESPRO.EXE in the EDGE dir.
4. Select the Sentinel tab, choose a filename for the result .dng
file, and press "Dump&Solve".
This can take some minutes depending on what type and how many
algorithms needs to be recovered.
The "Specify Developer Id" and "Specify Write Password" options
are for advanced users, and not required.
"Specify Developer Id" allows you to dump and solve from emulators
without physical dongle.
"Specify Write Password" allows you to dump faster, if you know
cell 4 (write password).
5 Now run SENTEMUL2007.EXE and press "INSTALL" button and if installation
was successful driver status window will be changed to:
"Status : driver is installed".
6. Now you need to open "Emulator" tab, Then you press "Start Service"
button. If everything is ok you'll see "SENTINEL Emulator Service
is running"
7. Open "DONGLES" tab and press the "Load dump" button, then navigate
to the .dng file you created with EDGESPRO.EXE
I have SDP3 2.6 running locked to yellow USB key from autokg. Anyone knows how to emulate it?
