Results 1 to 7 of 7
    alfons37's Avatar
    Default Ford transit problem
    I have ford transit 2.4 Dci 66kw year 2006, problem is car not start, no crank, pats lamp flash . I read dts and it say b1601 pats received incorrect ignition key code signal. and it say p1608 watchdog error, i erase all dtc all erase without b1601.
    When i read with autoboss v30 and it say 0 keys programmed in pats. Must i have ids for program when all key is gone in pats?
    Meat-Head's Avatar
    Quote Originally Posted by alfons37 View Post
    wiring loom on diesel pump above starter motor damaged
    check ecu has 5 volt output
    alfons37's Avatar
    Default Forgot
    I forgot tell is ford transit connect with engine code HCPA
    I check all cablage. Can i use immo off on this car?
    France
    Default Ford Transit
    you just have one key ?
    alfons37's Avatar
    Default key
    I have 2 keys and it with blue mark, i think is 4d transponder.
    France
    Thumbs up Ford transit
    check ALL fuses
    check ALL currents and ground at engine ecu
    if you can open engine ecu to see it (can be a bad soldering)
    Member trycktill's Avatar
    Dec 2010
    casablanca
    I have ford transit connect year 2003, problem is car not start, no crank, pats lamp flash . I read dts and it say b1601 pats received incorrect ignition key code signal. i erase all pcm .
    When i read with autoboss v30 and it say 2 keys programmed in pats. when i click on program key i get pcm coded operation faild i have one blue key any helo plz
