Results 1 to 9 of 9
Thread: Bosch Kts 650
    DK Veteran markony79's Avatar
    Jan 2009
    Sweden
    Default Bosch Kts 650
    I have bosch kts 650 made in 2004. the procesor is very slow
    400mhz. I want to change motherboard.
    From what lapotop is the same motherboard?????
    POLAND
    You need special motherboard for kts 650 there was 3 diffrent:
    1. celeron 400, 128RAM (possible to upgrade to 256RAM not more)
    2. celeron 650, 512RAM,
    3. pentium 3, 512RAM
    You can also change motherboard kts 670 pentium 3, 1GB, 80HDD and will be work with SD 650.
    Is Bosch KTS650 can work with Porsche PIWIS
    Feb 2011
    no, it can't . even with the esi soft porsche isn't really good supported
    DK Veteran ishell's Avatar
    Russia
    Quote Originally Posted by TanSH View Post
    Original piwis recovery dvd can power up kts 650 without any troubles .Same hardware uses.
    Just reflash kts with piwis firmware after restoring .
    I HAVE NO recovery dvd on hand now !
    Sure obd cable should be right prepared to porsche .
    FU#K GOOGLE. ASK ME
    Top Poster djorgensen's Avatar
    Cardiff, UK
    The 650 will work as a PIWIS if you reflash it, tried it and it worked. But you need the Porsche Recovery Disks
    Sep 2010
    Quote Originally Posted by ishell View Post
    to have the recovery disks piwis can be reprogrammed with the kts650
    Jul 2019
    Germany
    Quote Originally Posted by autorepair2 View Post
    I'm about to buy a kts 650 and i want to make a hw upgrade, but i don't know how to identify the hw before purchase.
    What identify marks have.
    Oct 2023
    Quote Originally Posted by markony79 View Post
    Its a SOM "System on Module" made by Kontron for industrial applications.
    So it's nothing "ordinary" from a Laptop, so no consumer gear.
