Results 1 to 9 of 9
    Default Elm 327 ver 1.5a . Please help!
    Hy there! I just have receive a brand new ELM 327 ver 1.5a interface that I have buy from e-bay. The problem that I have is that I cannot connect with the interface using any program. I have try with the Digimoto, and FiatEcuScan and I get no response from the interface. Since I am using Windows 7, I think it?s a driver problem. Let me explain this. I have downloaded the drivers from here FTDI Chip Home Page and it installed me in Device Manager the follow tabs: Ports (Com and LPT)-USB Serial port ; and another tab named USB Serial Converter. Well..in the tab Ports, I have the driver installed on COM4 , but when I try to connect with the software nothing happends. So...please give me a solucion.
    tomtom0785's Avatar
    Austria
    did you connect with power supply or Vehicle??
    enjoy and have Fun
    Tom
    Member radu_gostian's Avatar
    There is no elm327 1.5a. This probably is a china clone.
    You have to find which version it really is. If it isn't at least 1.3a then it probably won't work with fiat ecu scan.
    Use this http://www.scantool.net/scantool/dow.../5/stnterm.exe to check the version. The interface has to be connected to the car or you can supply it with 12V+ from some external power supply.
    Sep 2010
    you have to plug it on your car before and after check the port com , no matter the firmware version , just install the ftdi give with the cable , check the com speed (384000) plug it on your car and set the com on your obd soft .
    bogota(colombia)
    friend I only know that the best car program is the xp, the rest do not let the software work well, my advice is that you change back to xp, to touch me.
    Problem solved...It works connected to the ODB car port. And it?s a china clone, actually it?s a 1.4 version not a 1.5a version, but it?s work really great.
    i bought the elm 1.5a and i had to use com port 3 and it was a universal but it works great hope this help you out have a good day
    ANDRADINA ---S?O PAULO---- BRASIL
    HELLO DEAR FRIENDS HERE'S DK I need help.
    WHERE CAN I FIND SOFTWARE FOR ELM 327 V1.5A
    Dec 2010
    Ukraine
    You can find many programs on this tracker
    Scan XL Professional 3.2.0 [2010] :: RuTracker.org (ex torrents.ru)
