Results 1 to 8 of 8
    credoline's Avatar
    Србија
    Default 65535 error on 6Q0 909 605 A
    I repair one airbag unit 6Q0 909 605A index 04 from Golf 4 where is someone erase eeprom of MCU HC08. I have try with different files with index04 and 06 but i get 2 types of errors:
    65535 internal memory error
    or
    i get 2 errors which tell me that driver and passanger crash sensors are broken but car havent that sensors.
    My opinion is that is airbag modul broken while scaning with old VAGCOM or something similar. I need information it is possible to repair this error 65535 or not ? With changing data in eeprom i get nothing, maybe flash in MCU is problem ? Anyone has succed to repair this erros on this paticular model ?
    fuktak's Avatar
    Sep 2010
    Bulgaria
    Quote Originally Posted by credoline View Post
    or
    Get this one
    credoline's Avatar
    Србија
    That file i have already tested. Thats file give me 2 errors about crash sensors. I think that this file is not index 04
    szkeptmen's Avatar
    Hungary
    This is you need !!!
    Vag: 6Q0 909 605 A Component: 1G AIRBAG VW5 0004
    Soft coding : 12615 WSC: 00920
    AIRBAG VW5 Index [04]
    6Q0 909 605 A
    SIEMENS
    5WK4 2867
    rdu04's Avatar
    RO
    I had the same problem ... tested clear from szkeptmen 605a and I solved the problem ... thank you confirm the operation of the airbag computer tnks szkeptmen
    Dec 2010
    Just clear properly yours original dump. Erorr 65535 is also in there.
    DK Veteran magdex's Avatar
    POLAND
    ITs Hardware Error ! Check Drivers SRS ignition IC
    Member the_knok's Avatar
    Portugal
    or
    I
    Please put your original dump, so i can try to remove the error.
    REgards...
    If it was usefull, please hit the thanks botton. Is there for that reason
