Hi all' I have a reflex 3130 as a back up ,used it once in last year,
Is there any one who can unlock it from needing a smart card,Because ?500 to license it is unjustifyable,
Hi, I have a little bit different problem, I have got one of these with RTC battery dead. I replaced the battery, but the unit shows 'RTC corrupted', I have done some research and already know what microchip it is and I know how to program it. The only one problem is, the manufacturer probably stored some important data in the chip's RAM and they are gone, since the battery was dead. (RTC battery)
The system recognizes license based on the date/time clock, so when you change that, you will be able to use is again and again...
I am looking for somebody who can help me with that.
Thanks m8 i will give it a try
If u can work out how to down load a copy of the chip program from another 3130 let me know how & i'l see if i can do it from this one & send it to you ,
Hi I have a expired reflex3130 and I opened it and I saw the 8 pins chip which is the real time clock but it is scratched by manufacturer for not identifying that chip. I think must be seiko s35390 from power pins positions and from crystal position but did not know for sure. Can you tell me what kind of chip is and I will try to read it and send the dump.
Hi guys, Had no choice but to buy one of these - as a lot of members on here have them.
With the RTC gone and display showing corrupt - does it not do anything?
or can you access the date/time menu set up?
Meat
Maybe someone has a code generator for this device?
when you find one, pm me please
Meat
Can someone smarter than me can see what it is and how it start ?
Download tecnotest reflex 3130 - crack ,patch, serial, keygen ,
WHOA HANG ON THERE BUDDY, nil poi with these, been trying for months to get this off same site
Download sideward facing foo-foo valve repair and reset guide - crack ,patch, serial, keygen ,
(sideward facing foo-foo valve repair and reset guide)
Unable to get this as well
Download Winning lottery results working, love DK long time - crack ,patch, serial, keygen ,
So, keep looking
OFF TOPIC:-
If any member has the sideward facing foo-foo valve repair and reset guide, in Inglish rather than German or Russain, please upload it on here, thanks.
What software is the Technotest Reflex 3130 using?
