Page 5 of 5 FirstFirst 12345
Results 61 to 73 of 73
  1. #61
    HI!
    I've got a question...
    If I have a USA CAR Audi... Can I flash the Engine ECU with VAS and German File from DVD?
    Regards...
  2. #62
    ahadi's Avatar
    if the bosch and vw numbers are same for sure yes .
  3. #63
    turbocip's Avatar
    anybody can upload or share link for VAS flash CD?
    thanks in advance
  4. #64
    Jan 2016
    Quote Originally Posted by impactops View Post
    On each flash disc there is a "Label" file, the settings in this file determines the behaviour of VASPC with regards to the flash disc.When you copy the "datflash" folder across to "C:\SIDIS\home" the label file from that directory is used instead of the one on the flash disc since it is not copied across and therefore option 19 appears if the flash file is present and newer than the module you are trying to flash.
    Also another parameter in ediabas.ini located in "C:\SIDIS\home\DBaseSys2\EDIABAS\Bin" determines whether option 19 will appear.
    ; BipDebugLevel
    ; Description : Controls the check of the ECU version handling
    ; for flash programming
    ; Value : 0 = Versions with letters in the version string
    ; cannot be programmed (e.g. "X123")
    ; 100 = All versions are used for programming
    ; Default : 0
    BipDebugLevel = 100
    The default value of this setting is 0 change it too 100 as shown above.I have flashed the radio on a golf5, with this option set too 100, option 19 appears for the same flash file.
    On the same Golf5, option 19 does not appear for the ECU regardless wether the flash files are located locally or the value of the ediabas setting.Instead option "018.10 - Update Programming" appears for the ECU when using VAS5163 software
    Impactops
    Working Like a Charm mate!!!! Fabia simos 047906033 flashed on 047906033G !!!!!
    In default VAS dont show programming 19....
    thanks a lot!
  5. #65
    impactops's Avatar
    I don't believe you can brick the module you are trying to flash with an incorrect flash file, this will give you option 19 but it checks to see if the flash file is correct for the module regardless whether you try to fool it by renaming the flash file from another module to the same name.
    VASPC over ODIS any day! The rubbish there producing now with these enormous files sizes of auto Dealer software is an absolute joke
    Impactops
  6. #66
    Member Jerak's Avatar
    Jan 2011
    Canada
    Impactops
    Can I use a J2534 pass through device or must it be a VAS505x?
    Can VAS-PC downgrade flash files and flash modified files?
    I am not being facetious, I really don't know. Just looking for a flasher to work my transmission. Ecu would be nice too.
  7. #67
    Member ramianek's Avatar
    Aug 2010
    Please, someone is flashdata SK cd marken 23.
  8. #68
    Dec 2018
    thanks good job
  9. #69
    Any link for download flash daten from erwin or other web ?
  10. #70
    Feb 2019
    Krimea
    Friends, to what such complexity. I use to record ODIS engineering updates. Very simply. And I can record SGO files from other car models. Thereby optimizing or correcting the operation of certain electronic components. For example, on the Passat B6 there was a problem with the electric power steering, the power transistor burned out on one of the control phases. Replacing the electric power steering is expensive. Decided to forcibly firmware from Skoda RS.
  11. #71
    Some flash files (k-Line programming) not work properly in ODIS. I test Automatic Transmission VW T5 2007 control unit flashing and ODIS, VAG Can Pro, Abrites failed update. But VAS PC v19 with prepared .stt files programing without problems.
  12. The Following User Says Thank You to carmelasse For This Useful Post:
    impactops (18th May, 2020)
  13. #72
    impactops's Avatar
    A fully unlocked dealer software will give you more options than any bullshit overpriced aftermarket product like abrites would give you. These options exist so dealers have the ability to try things when they encounter problems instructed by the engineers at head office.In the case of VAG, dealers are not allowed to use Odis E and Odis itself like MB are becoming oversized and resource hungry putting tremendous burden on hardware which is not really required. The diagnostic data in most dealer software is becoming standardized and can be imported in software like softing DTS which is the backbone for VAG and MB.The VAS5054 (edic blue) is a PDU-API which is another standard amongst interfaces and with the j2534 wrapper the options become endless.
    Using imported dealer data from the dealer software rather than trying using the multiple dealer software on one machine or each on multipe machines is becioming easier and more feasable as time goes on
    Impactops
  14. #73
    Sep 2019
    Quote Originally Posted by milzal View Post
    look for dataflashen in the forum should be a thread
