Is there a way to get blink codes for ABS on Daf LF 55 2006
got a abs light coming on intermittent,checked wires to front sensors and no play in wheel bearings
Russell
Russell
tried cleaning exciters ,but too corroded.fitting new on monday.will let you know then
Russell
new rear discs fitted,had to go to dealer to clear stored fault codes
Russell
it`s a wabco or a knorr abs , if it is a wabco you can easy find the unit publication on wabco inform
Hello there i have got a Daf LF 55 with an ABS warning that will not go off,it came on whilst trying to reverse up to my parking place on 29-11-10 with diff-lock engaged i dont think my truck has even got ABS! How much did your dealer charge for clearing fault codes? Thankyou Cloudmaker.
have you got the wabco or knore bremse ecu part no
