Hello all,
Is there already someone that can generate a code for DiagBox ?? Thanks in advance.
Hello all,
hi OpenOBD
search google autokg ...the price is very expansive for activate.
There are people who will activate for around 50 euro that I know off, I sugest holding of a bit longer and maybe keygen will be available soon
Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
GeminiAutoLock (9th November, 2019), guja100 (19th August, 2024), Libatelep (3rd December, 2020)
someone tested it?
Somebody can tell if it's works with v04.57 ?
yes but you must to update to v04.86 http://www.digital-kaos.co.uk/forums...tml#post862400
Installation in ReadMe.txt
does it work on V5.06?
GeminiAutoLock (9th November, 2019), ker0de (19th October, 2023), marujo62 (15th August, 2022)
Both patches modify fr.actia.AWF.tags.GuiPSA_vc80.dll, they inject code by placing values into the registers.Versions 4.86 & 5.06 both have the same version dll, so you should be able to use the 4.86 path on 5.06 or just copy the patched dll accross.
Why not just remove the entire registration all together & have all options open?
Impactops
