Same problem for me, I briked my china mvci device after upgrate it to 1.4.7. Tring to dowload theevo17's file.
I discovered how to dowload this file: right button of mouse above the file link, copy the link and paste in another black page of your browser (I am using chrome).
However, I am trying to figure out how to flash my mvci with this hex file. The firmware update tools does not recognize it. Some one has a glue?
FINALLY IT WORKS!!!
Basically what you need to do flash the memory manually, using the ARM's software.
MY PROBLEM: I briked my china mvci device after using the Firmware udpdate tool, changing the firm. version from 1.4.1 (default) to 1.4.7
MY SETUP: Windows 8.1 64 bits.
SOLUTION:
STEP 1: Download the hex file attached.
STEP 2: Download Flash Magic (my version is 12.80 - build 5762)http://www.flashmagictool.com/downlo...l&d=flashmagic
STEP 3: Connect the mvci device to an USB port
STEP 4: Open Flash Magic, select LPC2119 (LPC2000) in the field device
STEP 5: Select the serial port: my serial port was COM3, try to remove the mvci device and plug it again to see if the FlashMagin detects the COM port automatically (maybe is better to remove all others USB devices during the process (my case))
STEP 6: Baud-rate: I selected 4800, but maybe other (higher) can provide a fast flashing.
STEP 7: In the Firmware panel update the .hex file.
STEP 8: Press the giant button START. The flashing should start, it takes a while (20 min aprox. for me)
STEP 9: When Fash Magin get out of the busy state, the process is finished, close the software and remove the device of USB port.
To confirm that it was restored to 1.4.1 version open the HDS driver Firmware Update tools and check the firmware version.
Again, work for me! Good Luck!
alaz (31st August, 2022), evilmaster (27th April, 2021), JarekS (1st March, 2020), kelleci (20th August, 2021), mmm323 (10th May, 2020), mtayubs94 (8th December, 2020), patrolll (14th February, 2023), seya14 (17th August, 2020), ssweat (19th April, 2021), torzet (14th December, 2020), TOYTEC (15th January, 2024), tubasteve (27th May, 2020)
Hello. I have a similar problem. Thank you for the hints on how to solve it. Greetings to all.
can i downgrade to this firmware
HERO, I guess it has been a while and forgot i 'UPGRADED'. Thank you
kingkev843 (6th October, 2020)
Can't download the file! Help please!
Hi, i will try your solution lets hope it works for me. thank you for this guide
alaz (31st August, 2022), evilmaster (27th April, 2021), sparkywar (20th September, 2021), ssweat (19th April, 2021)
