Page 1 of 24 12345611 ... LastLast
Results 1 to 15 of 359
    Default Lexia PP2000 repair
    Hi all,
    Interface correct connect PC.No communication cars.Not working relay and no power PIC16F684, relay etc..
    Need dump flash W25x80AV.
    THX
  2. The Following User Says Thank You to Anydraj For This Useful Post:
    Col19 (24th January, 2020)
  3. #2
    1.if there is no power in PIC, check Q4.
    2.if there is no +5 V, check LM2674(U5) and diodes D3,D4.
  4. The Following 2 Users Say Thank You to AGK For This Useful Post:
    Col19 (24th January, 2020), titoun (18th February, 2016)
  5. #3
    DK Veteran MOBILTRONIC's Avatar
    Bosnia & Herzegovina,Cazin
    Check,mate,V-mos transistors on other side pcb,one by one.Only one is defect.Cheers!
  6. The Following User Says Thank You to MOBILTRONIC For This Useful Post:
    Ximot (1st May, 2023)
  7. #4
    Quote Originally Posted by AGK View Post
    LM2674(U5) and diodes D3,D4. Check OK.
    PIC No power
    Q4 ?Crystal 4.000 MHz --> OK
    V-Mos transistor ?Check foto pleas.
    THX
  8. The Following 5 Users Say Thank You to Anydraj For This Useful Post:
    Cinek75 (7th March, 2016), Col19 (24th January, 2020), Dalautos (10th April, 2019), Ximot (1st May, 2023)
  9. #5
    Bin dump to my board
    Procesor M90F
    PIC16F684 + fuses /fuses only hex/
    Flash 25x80AV /25X40AV/
    Foto fuses for Asix Presto programmer
    OBD and Interface wiring /autor DITEX/
    any ideas....
    thx friends.
    ANYd.
  10. The Following 29 Users Say Thank You to Anydraj For This Useful Post:
    Adi202 (2nd April, 2023), AlexDi (15th March, 2023), Anatolijus (18th May, 2018), brodaty (3rd November, 2016), carpin (10th September, 2018), Cinek75 (7th March, 2016), Col19 (24th January, 2020), Dalautos (10th April, 2019), darkwooddark (7th April, 2021), flashs (19th May, 2023), fluorescent (30th June, 2016), gkanev (12th April, 2023), hbalazs (22nd March, 2016), hedi makhlouf (2nd February, 2017), hmagga (26th September, 2022), johny2h (16th June, 2016), kral06060 (14th July, 2017), kronk92 (9th November, 2016), mcb58 (2nd December, 2017), mexanico1971 (19th March, 2015), miltas (21st February, 2018), nikiver4ov (22nd September, 2020), okm (6th February, 2018), rrr500 (4th July, 2018), shtyrya2 (26th September, 2022), thunderwinged 2 (5th June, 2020), titoun (18th February, 2016), varoff (31st January, 2017), Ximot (1st May, 2023)
  11. #6
    And fuses for Asix Presto...
  12. The Following 8 Users Say Thank You to Anydraj For This Useful Post:
    carpin (10th September, 2018), Cinek75 (7th March, 2016), Col19 (24th January, 2020), Dalautos (10th April, 2019), darkwooddark (7th April, 2021), gkanev (12th April, 2023), nikiver4ov (22nd September, 2020), okm (6th February, 2018)
  13. #7
    Quote Originally Posted by Anydraj View Post
    Procesor M90F
    any ideas....
    thx friends.
    ANYd.
    On your photos, check D1 and may be T3,T4 (hard to see the notation of transistors).
    One transistor (2N7002) is connected with 4 pin PIC, the other with 1 pin .
  14. The Following 2 Users Say Thank You to AGK For This Useful Post:
    Col19 (24th January, 2020), mcb58 (2nd December, 2017)
  15. #8
    Senior Member gixxer's Avatar
    Mar 2009
    Europe
    Lightbulb green LED
    Hello
    My Lexia3 if connect to PC , green LED lighting about 1.5 sec after nothing, and no communication for software.
    Please help...
  16. #9
    Roma's Avatar
    UK
    I have for old lexia progam for repair lexia and peugeot
  17. #10
    Default Lexia PP200 repair
    Quote Originally Posted by gixxer View Post
    Hello
    Please help...
    Hi,mates.For fixed interface must change it RAM memory
  18. The Following 5 Users Say Thank You to MOBILTRONIC For This Useful Post:
    Cinek75 (7th March, 2016), Col19 (24th January, 2020), FeerLaas (21st June, 2019), johny2h (17th June, 2016), titoun (18th February, 2016)
  19. #11
    PIC No power
    THX
    Yes mate,you try change it 2N2007,V-mos transistors.
  20. The Following 2 Users Say Thank You to MOBILTRONIC For This Useful Post:
  21. #12
    Thanks.I look.RAM removed, It did not help.
    Transistor 2N2007 or 2N7002 ?
  22. #13
    Member butugan_mihai's Avatar
    Iasi-Romania
    Default pp2000 died
    Hi friends!I had version 22.95 and everything was fine .. after I installed the 24.01 version, can not communicate with the car and get the following message:''comunication error''!I mention that use this interface for 3 years and I did update the internet every time without problems.This worked well one day then did update and died.Any idea?Interface corect conect with pc but not comunicate with car!
  23. #14
    meteor80's Avatar
    Hello All.
    Did someone fixed up lexia.
    I have the same problem, interface comunicate with PC but not with CAR.
  24. #15
    Mar 2009
    Europe
    Quote Originally Posted by MOBILTRONIC View Post
    This "new" RAM must flash or only change?
    Thank you!
