hi all,
love the site, bit of a newbie, but want to show my appriciation somehow, if anyone wants terex bcs service codes or how to make leibher service keys or Hitachi winDR let me know and i will see if i can help,
cheers
hi all,
cheers
3k ohm = green
10k ohm = red
press thanks!
just realised the pin configuration could help,
its across pins 4 and 9, of a RS232 DB9 plug. the same as a laptop serial port,
cheers
ZyloLB (30th October, 2024)
the two keys are put in the same resistance pin
Can you please post a schematic for the Liebherr key?
Thanks!!!!
buy a seriel/db9 plug, from your local electronics store and solder either a 3k ohm for a green key or a 10k ohm for a red key from pin 4 to pin 9 then plug it into the digger just above the right armrest, cheers
i cant remember if this is a male or female db9 plug?
male pins, digger side is female,
yeh all good there are 2 female ports and one male port on the ESP01 card, just wasnt sure which one the key was suppost to go in, i aquired a genuine green key and made a red key. Have you seen LTS software available anywhere?
Help with the scheme
Does not work soldered to 4 and 9 pin
So you can just put a 10k resistor in 4 & 9 pin?
