Page 2 of 9 FirstFirst 1234567 ... LastLast
Results 16 to 30 of 128
  1. #16
    I have 30.006 PM me and I will e-mail it to you
  2. #17
    is it possible to update clone throug Tis web or not what are you guys useing clone or originals?
  3. #18
  4. #19
    Dec 2010
    How do you install this, I found only 32 MB bin file inside the archive.
    Juuso
  5. #20
    Quote Originally Posted by juuso View Post
    Juuso
    That's all it is.
    It is totally useless to you unless you have a GM MDI, in which case you find the tech2win software in this thread, install that and then use the 32mb image.
    or
    You have a tech2 and use Memory Card Explorer to write it onto the memory card.
    If you have neither, then don't worry about it.
  6. #21
    Dec 2010
    Thank you for your answer and my apologies putting in a stupid question, I am a noob with GM devices.
    I have Tech2 and and MCE is the thing I was looking for.
  7. #22
    puiu's Avatar
    Timisoara
    Quote Originally Posted by tramman View Post
    All done and loaded found a compatible pci-pcmcia adapter and Tech2 now running 122.023.
    Can you tell me please what adapter have you used ,is 12V VPP compatible?
    Puiu
  8. #23
    puiu's Avatar
    Timisoara
    Hi friends,
    i need help to load NAO 30.007
    in Tech2win ,
    thank you
    Puiu
  9. #24
    You just have to put image in correct (\pcmcia\) folder and edit config file.
  10. #25
    But i don't know how GM NAO software work in Tech2Win.
  11. #26
    DK Veteran ibmman's Avatar
    Living Hell
    It isn't against the law to ask for help. Sometimes it is better to use the search function but if you can't find it there then I would not mind helping you. We were all noobs here at 1st and sometimes we forget that we were. Enjoy all the benefits of DK and make sure you do your share of contributing.
  12. #27
    Living Hell
    Quote Originally Posted by MBGL View Post
    Most newer laptops will not write to the 32mb GM card using Memory Card Explorer. I use an old Dell laptop that is able to write at 12 volts.
  13. #28
    I was able to write the card bin using Cardware, by Apsoft. Cardware makes another boot profile that configures the pci bus to program linear cards. Ive loaded quite a few laptops and they all worked! Hope this helps!
  14. #29
    Newbie Skeeter35's Avatar
    Mar 2011
    I have the latest update for gm nao. I believe its 31.07 pm me if interested.
    Also if anyone can help me with some card issues I'd appreciate it.
  15. #30
    puiu's Avatar
    Timisoara
    Quote Originally Posted by sledfreak76 View Post
    after i updated my card with TechII,i was unable to write the card with my notebooks,i have many models and no way,
    allways i had the "No 12V hardware" eror,
    and now i tested Cardware and is working !!!
    Thanks so much ,this is great
    best regards
    Puiu
  16. The Following User Says Thank You to puiu For This Useful Post:
    nazz2 (7th May, 2015)
