You need to install ios 224 (57) v5.1 from here: using wad manager
then set config usb
- Configurable USB Loader -> Select The Game-> Press 1 to go into Options-> IOS = 224 you want to use for the game -- Press 2 to save
then set config usb
Tried 224 [57] v5.1.wad on CFG rev 60 with no luck, tried 249 [57] rev20.wad and it worked on CFG rev 60.
Tried disc load { back up} 249 [57] rev 20 on Neogamm r8 and worked, but the wii was grunting and groaning at me, any idea's anyone ? on the noise that is?
Red.
also working for me on 249 [57] rev20.wad with loader gx
please press the little red THANKS tab
if I helpedif not press the green tab to tell me to f**Koff
sometimes life will kick you around , but sooner or later , you realize you`re a warrior , and your stronger than anything life throws your way !!!!!!!!!!!!!!!!!!!!!!
Still can't get usb loadergx to work tried both 249 v19 & V20
and 250 V20 wondering if it's the game!!!!!
the only reason I have not tried another loader is because all my other games work fine
What version of the COD game are peeps using?
mine was (imars-codbo PAL)
I put the game on my HDD, selected IOS224 under uLoader 4.9 but it hung whilst loading the game. So I assume I need to upgrade my cIOS224.
I've downloaded those 5.1 packs but TBH I'm not sure what to do with them. Should I put the boot.dol from the cios_installer folder of the uloader archive into the root of my SD card and boot from SD just to upgrade the cIOS or should I do the whole lot?
Would it be easier to use the internet updater? Will that do uLoader and the cIOS and still retain my forwarder channel or should I remove that first?
That's the trouble with these kits that do everything for you; when something goes wrong you don't know bits to replace!
Please forgive me i usually only hang out on the satellite boards but was wondering if any experts can help with this. I'm trying to load an ntsc version on a softmodded wii from disk, running neogamma r9 b47 cios57rev 20 and i keep getting a black scree. The same happens when using uloader. Any ideas where i'm going wrong, its starting to drive me a little nuts now. Cheers Bert
Tried loader gx 937 & 938 but found it not working as smooth as older version installed as a channel
will give this another go I'll check game with another usb loader Maybe config usb loader and reinstall iso249 & 250
can't believe i'm having this much trouble
thanks for the help
The version of gx shouldn't matter just put Digital Kaos - Downloads - cIOS240[57]-v20 for COD black ops in wads and install. I know this is working. If you still have problems try another iso. I have just noticed the link says cIOS 240 it is 249 I have just edited in downloads, sorry if it's confusing peeps.
Last edited by happy_highlander; 12th November, 2010 at 09:17 PM. Reason: I'm an idiot and don't look ot titles when uploading.
See that's the thing about you ck-ok. You're the f?cking man. I've just tested zombie mode and online with no issues whatsoever.
Running uLoader 4.9 with an upgraded version of cIOS224.
Rep added. Love you man.
edit: but out of interest, how did you know about the base 57 bit?
Last edited by Timmaa; 12th November, 2010 at 09:35 PM. Reason: added the question
Has anybody got it to work from backup disc yet?
