Results 1 to 9 of 9
    malczykos's Avatar
    POLAND
    Default How to program remote VW FOX
    Hello.
    I am looking for information on how to program the remote to VW FOX 2006. I tried to do with the VCDS, 46 - Comfort module.
    However, without success, the channel 01 away.
    Does anyone know the procedure to program the remote control in this car? Old remote stopped working after battery replacement.
    Best Regards
    Hi, you need two keys for programming remote,
    with the simple key turn switch in ON position.
    keep out of the car, close the door , insert key in dor cilinder and
    hold turn to left, press lock button 3 times or more .
    end of operation.
    good luck !
  3. The Following User Says Thank You to jnegretti For This Useful Post:
    achopicha73 (15th August, 2018)
    But you should also have in mind that if the battery of the remote control is flat, the key wont progamme take note
    of course !! man
    malczykos's Avatar
    POLAND
    Quote Originally Posted by jnegretti View Post
    end of operation.
    good luck !
    Client has only one key.
    The battery in the remote control is good.
    you need make one simple copy with transponder, program both with VCDS, and make manual procedure for programming remote
    to work, man !!
    malczykos's Avatar
    POLAND
    to work, man !!
    Thanx. This procedure is works!
    p1et's Avatar
    Oct 2013
    end of operation.
    good luck !
    This procedure is not working for me. Is there any other method I can try?
  10. #9
    rafal's Avatar
    UK - PL
    Quote Originally Posted by p1et View Post
    try:
    - press unlock
    - switch ignition on
    - press unlock two times within 5 sec
    need help
    now my goal is to buy xp-005
    who will help?
