Hi all
I have Opel Astra G x16xel i read ecu galleto.
Is it possible virgin this ecu?
Hi all
What chip is this, what flash chip is in ecu? and what eeprom too?
Try to make SPS programming with TechII
sometime helps...
Puiu
Hi friend , If you know S.C code new (used) ecu adaptation very easy. (for x16xel )
E.g S.C 0587 of old ecu , s.c 1234 of correct car
you will connect immobiliserII , then reset immobiliser function
Then you will enter immobiliser code as 0587, and program fixed immobiliser function
Impossibel immo transfer for opel hybrid ecu via flash program
you are must be know S.C of used good ecus
you are must be buy products from codecard,smokk and similar compony
Or if you have good a friend in the opel dealer , you can learn S.C via VIN number
WBR
kasim
If the code that you posted is really for this ecu, Why you need virgin this ecu?
install new used ECU on car and
try to read the code from your new used ECU,
with OP-COM german ver. 090420
search this forum somwhere is posted how,
this is the only way to do it without special Tool like Carprog ....
regards
Puiu
if you need the above mentioned ver of OP-COM pm
Puiu
I have same car with ecu 16228919 but i need immo off for i have problem with immo. Can i do immo off on this car?
