Page 6 of 9 FirstFirst 123456789 LastLast
Results 76 to 90 of 129
  1. #76
    Mar 2011
    Default Offline coding with keygen from Jc
    hello, i have the keygen from jc for offline coding.
    This keygen was protected with dongle.
    Original from JC the keygen is pc limited.
    I have this keygen without pclimit.
    This keygen have two files, one .exe and one .dll file.
    I think that in this dll file was the searching for dongle.
    Is there anybody, who can delete the searching for dongle?
    The name of dll is: DAS PASSWORDS_R7Runtime.dll
    If anybody can help me, please PM me.
    thanks for your help.
    regards
    Cheng
  2. #77
    DK Veteran cocoh's Avatar
    Jun 2009
    Quote Originally Posted by ChengLynn View Post
    regards
    Cheng
    well... this is the tool Rockey7.NET Shell Tool which protect the KG..
  3. #78
    May 2011
    Default scn coding off line
    does this really works off line,I only heard about it,my understanding can be done via fdok on line,any idea?
  4. #79
    May 2011
    jc recording money for everything...
  5. #80
    Default scn coding
    is this valid to flush 7 g tronic???
  6. #81
    Quote Originally Posted by bobbocardiag View Post
    Yes it is, some did it on w211, so you can too
  7. #82
    Aug 2011
    Thx it's work
  8. #83
    Oct 2011
    Thank you I'd like to try it
  9. #84
    Quote Originally Posted by Ne0 View Post
    "Offline" programming in newest DAS version - You need ? - Good! It's very simple - copy this file to
    F:\Programme\DAS\trees\pkw\flashen\ini
    (click yes, to replace existing).
    And Be Happy !!!
    if you not have this function for any concrete car - check first six VIN digits for this car, and add to this file in model section.
    for sample - to enable option for WDD221054 - add text string to file :
    221.054=YES
    Regards,
    Ne0
    THANKS FOR FILE
  10. #85
    DK Veteran labusas's Avatar
    Nov 2010
    Hi, mates
    Who can confirm which digits to pic from this VIN for flashen.ini edit:
    WDBUF26J86A98XXXX
    I tried 211.268=YES with no luck
  11. #86
    Quote Originally Posted by labusas View Post
    Hi, mates
    WDBUF26J86A98XXXX
    You have to give the complete VIN (or PM) to enable reading of internal VIN. But I guess you did that yourself in which case you must have a different issue other than the model designation.
  12. #87
    Nov 2010
    Thanks DB
    Please advise how to enter for VIN WDBUF26J36A962726?
    In the first post it says first 6 digt of VIN are required.
  13. #88
    Thanks DB
    Please advise how to enter for VIN WDBUF26J36AXXXXXX?
    The internal VIN of this car is WDB2110261AXXXXXX, so you have to have 211.026 on the list.
  14. #89
    Nov 2010
    Is it possible to find this from regular VIN or is it only in Star Diagnosis?
    Is it like this:
    211 = chassis
    F= 0
    First two #= 26
  15. #90
    Is it like this:
    211 = chassis
    F= 0
    First two #= 26
    I believe the first letter of the external VIN after "WDB" gives the body style, like
    - U for MB means 211
    - F means Sedan
    - next two digits are the model within the body type, seems to be a direct copy from the internal VIN
    - next digit is about the SRS system, I've found explanations up to the letter F, so this car must have more SRS equipment than known when my reference was drafted
    - position 9 is a check digit and the tenth digit comes from the model year.
    It is much easier to find this if you enter the external VIN to EPC and let it decode the internal VIN for you. Then pick up digits 4-9.
