Results 1 to 15 of 26
    Lithuania
    Default Toyota AIGO 2007 key program
    Hi, today I tried to program new key to TOYOTA AIGO 2007
    But car not starts on scan I have INCORECT KEY CODE.
    Used 4D 67 chip
    How to program key?
    I readed 95040 from bosh ECU, and readed key with zed bull. does it possible manually enter key data to eeprom ? or make virgine ?
    Not 100% sure, but i believe data in your dump sent here is for IMMOBILIZER ECU - Engine ECU Synchro.
    In other words, this car seems to have an IMMOBILIZER ECU which location may at the Radio location,glooves Box or above the brake pedal behind the dashboard.
    This assume, look it at the area indicated open it and read dump from the memory device: 8 pins eeprom s93C66 SMD and post here;there are many able members in this forum that can help you.
    Good luck
    if you have one key you can program more keys using p planet i now beleive sbb can do it too
    There is no key code for aygo/107/c1
    if you have no keys for the car then you have to virgin the key module and then program new keys using p planet ( not sure if you can use sbb when all keys are lost )
    key module is under dash cover behind speedo head
    you have to remove the whole top of the dash to get to it and make sure you get the right box (there are two, it's the lower one) it's secured with shear bolts
    hope this helps
    Lithuania
    Hi to all, with your help I found immobox....
    so I uploaded new zip file in my first post with ecu, immo and new key data....
    Please help to solve that problem...
    But if I try to program with peugeot planet as P107 I think it will ask for pin like all peug and citroen have ???
    I have T300, SBB and AUTOBOSS for programming key also peugeot planet
    Quote Originally Posted by darius89 View Post
    good you found the immo box
    i've not done aygo but have done loads of 107/c1
    you don't need a pin because it's toyota system
    you need virgin file for immo
    when you program with planet/lexia it asks if you have fitted new immo box
    you can program only one key if you want
    have a look on your sbb because my v32.2 says it does psa aygo/107/c1 but i haven't tried it yet as i always use planet etc
    i have the virgin file for the immo box let me know if you want it
    on the sbb go to toyota psa and try it. it gives aygo/107/c1/yaris
    Lithuania
    Please give me virgin if you can.
    darius hows it going and did you get the file ok
    Lithuania
    Thanks but not worked for me tried to adapt like p107, like c1 and with sbb like AYGO.
    After programming with pp2000 I got :
    best way is to enter key data to immo 24c04
    tryed to syncro ecu to immo but nothing
    key used 4d 67
    Did you made virgin ????
    just compare my and yours ...
    key used 4d 67
    darius think you are using wrong 4D transponder
    the ones I use are 4D not 4D (67)
    what did you get when using pp2000
    i go into key learning it asks if you've fitted new immo and then program key
    if you say no to fitted new immo you have to have original key
    i'm not sure, because i haven't done aygo, but it is exactly the same as 107/c1
    did you remove chip to virgin it ??
    Lithuania
    Hi, yes chip was removed when vinginized. I tried with new immobox, and not new... the same.
    did you used 4D (60) ... I found now that should be this.... in silca webpage
    key used 4d 67
    darius you have info missing on that file
    what info you have is on mine too but there is a lot missing
    Lithuania
    everything ok , I just captured that part about wat I'm talking
  13. #13
    this is what is on the virgin file
  14. #14
    cmon man get a grip (ha ha ha)
  15. #15
    Lithuania
    Does anybody else has solution for my problem ?
    Who knows how to enter key data manually ???
