Results 1 to 15 of 16
    drpeter's Avatar
    The Netherlands
    Default xprog k-line adapter EWS 3
    I want to buy a xprog m only for ews 3 modules, does it work by K-line?
    If I buy one from ecutool the k-line adapter comes with it?
    At this moment I am using UPA with a selfmade script but I don't like to cut two wires onboard.
    I bought a EWS3 module for test, found better solder points for UPA but still have to cut those 2 wires. If I don't cut the signal is too low.
    I also want to save time by using xprog.
    stefaudio's Avatar
    BULGARIA
    for my it work,y try one time onli wit D46J ant worked,wit D47j not tested.y buy mine xprog from local diler hir in bg and kame wit ews3 adapter but adapter its sow izi to make alone
    sori bad english
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by stefaudio View Post
    sori bad english
    I understand, you only have to solder one wire onboard then I think. I am afraid if I ask ecutool if the k-line adapter is included they don't know where I am talking about :-).
    thanks.
    looks like k-line adapter is included in the latest set but it will also work without I guess. K-Line, VCC, GND and B4 you will find on the connector where the yellow arrow is pointing to.
    stefaudio's Avatar
    BULGARIA
    you dont need k line adapter adapter its nothing use onli
    +12v
    gnd
    K line direkt from X-progM socket
    mcu modb 22pin to gnd
    obdmaster's Avatar
    Never never land
    Thumbs up
    Quote Originally Posted by drpeter View Post
    thanks.
    The k-line adaptor is included now from ecutool, i have a xprog-m from ecutool and it is included m8, but as said you dont really need it m8
    You need every tool in the book, to do this auto locksmith job.
    DK Veteran almeida's Avatar
    hello peter,
    yes the adapter came with xprog, if it works i?m not sure because i not try yet.
    but for sure it works.
    only need to connect 3 wires to the plug and solder 1 wire in side.
    look the picture.
    chhers
    bram380's Avatar
    Indonesia +628153111774
    My Xprog-m clone has been used successfully read & write to EWS3 (HW-03 SW-08) several times.
    einet's Avatar
    I bay mine bay ECUTools and and only work 4 times, and still there over a month...................!!!!!!!!!!
    I don?t tray anymore ECU and sino....
    one member are fuc*ed 2 times on ECUtools.
    This is what i can say!
    einet
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by einet View Post
    einet
    I don't work for ecutool :-) but I never had problems with ecutool products. If you buy clone stuff you must know that sometimes things don't work, they are resellers with no technical background. So you can't expect to get any support but you get another one if its not working, so no big deal.
    I ordered my xprog tonight at ecutool.
    i'm dealing with ecutool for the past 3 years. never had problems with them. it is also depending how you talk to the people...
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    I have xprogm from autokmfactory.com
    [ame=http://www.youtube.com/watch?v=f8sQWFfjEcg]YouTube - EWS3[/ame]
  13. #13
    hello,
    today i try my xprog with the ews, not working they say initializing device and nothing happened.
    i try with the upa, and read at first time.
    some one have some tip for that.
    could have some ews that not read....
    cheers
  14. #14
    Macedonia
    Buy cas 3 programmer it is so simple to use
  15. #15
    my friend,
    when post comments try to post only what you know about.
    with cas3, and i have one, you can?t programme ews3.
    you only could programme ews4 that you find for ex X3, X5
    good lord...........
