Page 1 of 4 1234 LastLast
Results 1 to 15 of 57
    Nov 2008
    Default Tutorial how to update tomtom navcore and map for first timers
    How to update tomtom navcore and map for first timers
    Things you need to do before update
    Always backup your tomtom first to your pc, using windows exployer, copy and paste.
    connect tomtom to pc start exployer navigate to your tomtom drive which should show
    up as a removable drive and copy all files on your tomtom to a folder on your pc mybe
    called tomtom backup.
    Or better still buy a new sd card 4 gig and format it to fat32.then copy tomtom sd card files to new sd card.
    i would try all updates without updating bootlader first.
    To run bigger sd cards you will need - full support for SDHC on all Tomtom
    models,also needed to use Navcore 8.412 and 8.410
    Bootloader_5.5122.rar
    copy the file system to tomtom.make sure your battery is fully charged,tomtom will
    restart twice, bootloader updated
    Lets say we are going to update a tomtom 1
    The first thing we need to do is delete the old map folder from your tomtom.
    you can leave your navcore alone or install a newer navcore to get alg the choice is yours, navcores 7.903 and lower don't support alg, if you want to keep your official navcore/app then miss out 1.
    1/ download your navcore/app which would be 8.410 from SE__Navcore.8.410.1218.Basicpack.rar
    unzip the file and copy the files within the folder to your tomtom, overwriting any files if asked.
    restart tomtom once to create ttgo file.
    connect tomtom to pc again.
    2/download the map of your choice, lets say United_Kingdom_and_Republic_of_Ireland_865.3245
    from link- United_Kingdom_and_Republic_of_Ireland_865.3245.pa rt1.rar
    United_Kingdom_and_Republic_of_Ireland_865.3245.pa rt2.rar
    unzip the 2 files by clicking unzip on the 2rd file and you should see a file called 860.3101,
    within that folder you should have a folder called United_Kingdom_and_Republic_of_Ireland_860.3101
    copy that folder to your tomtom.
    uk & roi 870.3391.rar
    new map update United_Kingdom_and_Republic_of_Ireland_875_3613
    85747513.rar - 4shared.com - online file sharing and storage - download
    new map uk & roi 880.3810
    United_Kingdom_and_Republic_of_Ireland_880_3810.ra r - 4shared.com - online file sharing and storage - download
    new map United_Kingdom_and_Republic_of_Ireland_885_4055:mapuk8854055.rar - 4shared.com - online file sharing and storage - download for any navcore,but no iqroutes or alg.
    new map united kingdom & roi 8854009: ukroi8854009.rar - 4shared.com - online file sharing and storage - download
    map for navcore's 8.2-9.2 with iqroutes & alg
    After you have updated your map, you will need to update your postcode file, if you want the latest postcodes.
    the folder for your postcodes is called ZIP which is in the root of your tomtom.
    the latest maps are ver 880 so the latest postcodes are 880zip, which you can get from here.
    Digital Kaos - Downloads - 880zip
    885 postcodes zip here :885zip.zip - 4shared.com - online file sharing and storage - download
    unzip file and copy zip folder to tomtom root, replacing any folders
    advice
    where ever you get your maps from always check map comparability chart so you get the correct map for your navcore
    3/ download speed cams from http://www.digital-kaos.co.uk/forums...ularly-257126/
    unzip file and copy the two files -Safety_Cam_UK_Premium.ov2 - Safety_Cam_UK_PremiumOv2.ver
    to your map folder United_Kingdom_and_Republic_of_Ireland_860.3101
    4/ download fast activate http://www.digital-kaos.co.uk/forums...ate-2013-2511/
    read instructions.copy fast activate.exe to your tomtom, then while still connected to pc run fastactivate from tomtom
    click on update meta.txt tab, when updated, then click maps/speedcams tab to patch maps and speed cams.
    job done
    advice
    The navcore i used in this Tutorial is a se navcore which is already patched ,but if you use a different navcore you will
    need to patch ttsystem using fast activate
    if you need advice in the forum,it is always best to post your device info.
    you can do this in 3 ways
    1/ connect tomtom to pc, open windows explorer, navigate to removeable drive of your tomtom.right click ttgo file in root of tomtom,
    properties, type of file , click change and open in notepad then post info from file, don't post DeviceSerialNumber= or
    DeviceUniqueID.
    2/ tap bottom right on tomtom then, tap version for info
    3/ go to main menu page 3 and tap status & info tab,then version info.
    please leave feedback good or bad
    Apr 2009
    taximan thanks been useing same map for 4 years now so was well out of date thanks to taximan for this Tutorial im all up to date
    Dec 2010
    Taximan can you please re-upload the speed cameras. The link above takes me to the file hosts main page.
    Nov 2008
    updated speed cams link today. thanks for letting me know
    cleggy does a great job updating speed cam files
    http://www.digital-kaos.co.uk/forums...gularly-51725/
    Nov 2010
    Hi Taximan,
    great tutorial I have transfered the Navcore posted onto my TomTom and used Fastactivate posted above. I am trying to get part 2 of the UK Map but the download source does not seem to be working. Once i eventually get that, where do i put the new map folder and how do i activate it?
    Also is the bluetooth, show lane images, voice control preferences, enable wireless data, my tom tom account and tomtom buddy are all greyed out. Is this because of the device im using or the software?
    Below is detail you want
    [TomTomGo]
    DeviceName=TomTom XL
    DeviceVersionHW=ONE XL (v9)
    DeviceSerialNumber=**********
    DeviceUniqueID=********
    RamDiskVersion=20090213
    BootLoaderVersion=55136
    LinuxVersion=286217
    ApplicationVersionVersionNumber=8410
    ApplicationVersion=1218
    UserLanguage=English UK
    UserName=******
    LastConnectionTime=Never
    GPSFirmwareVersion=
    BuiltInColorScheme0=Belgica
    BuiltInColorScheme1=Brittanica
    BuiltInColorScheme2=America
    BuiltInColorScheme3=Germanica
    BuiltInColorScheme4=Australia
    BuiltInColorScheme5=Deuteranopia
    BuiltInColorScheme6=Greys
    BuiltInColorScheme7=Antarctica
    BuiltInColorScheme8=Africa
    BuiltInColorScheme9=Astra
    CurrentColorSchemeBuiltIn=0
    CurrentVoiceInfo=Jane
    CurrentMap=United_Kingdom_and_Republic_of_Ireland
    CurrentMapVersion=835.2420
    CurrentHomeLocation=*********
    Traffic=N
    CurrentFuelpricesType=
    CurrentFuelpricesTypeString=
    CurrentFuelpricesLastFullUpdate=
    ValueRatio=BRHJPF06f3ZktVz5Qw==
    Features=HDTraffic,Hercules,HerculesTraffic,Oxford ,TrackMe,PlusOnlineCamera,PlusTripReporting,OnDevi cePayments,HidRemote,HomeBackup,GPRSEngine,VoiceRe cording,TTS,TTSCompressed,TTSLoquendo700,MP3,IPOD, MusicPlayer,PhotoViewer,PhotoJPGViewer,PhotoBMPVie wer,VoiceBrowser,LinkVolumeToNoise,MapShare,Newyor k,Itinerary,Caymann,Durham,Leeway,PhoneFeatures,Ca rSymbol,TextureRendering,ExtraSounds,UserSkin,Rich POI,RDSTMC,Prague,SDSlot,InternalFlash,Microphone, ExternalModem,SupportGetAMap
    SupportedPatchTypes=3F
    NrSupportedErrorTypes=132
    UserPatchDatVersion=102
    CompressedPatchVersion=150
    MapServerPatchDatVersion=104
    DeletedPoiDatVersion=200
    ServerLineIndexDatVersion=102
    ServerNameIndexDatVersion=102
    MapShareSupportedProviders=203
    CharacterSet=Latin-1
    VehicleBrand=
    VehicleModel=
    VehicleOptions=
    Cheers Taximan
    P.S Sorry for being a noob
    Feb 2009
    hi taximan..need ur help again .i just notices ive only got a 3 digit postcode,can u sort me a 6 or 7 digit p/c...i found 1 in my v4 backup folder but it is dated 2008....and do i put the post/c folder in the uk/roi folder/?.hope this make sense...thanks
    xant14's Avatar
    Mental Mowbray
    Quote Originally Posted by mikie64 View Post
    Here ya go.
    Unzip the file called zip, and place the folder in the root of your tomtom.
    Digital Kaos - Downloads - Postcode file for Tomtom
    Nov 2008
    nice one xant, beat me
    but if you want the latest post codes for 860. maps here it is http://www.mediafire.com/?gs7vv6l387o6spg
    then follow xant instructions
    Nov 2008
    no1male , do you pay for tomtom services, if so whicht?
    map folder goes into root of tomtom, backup old map to pc , copy and paste, then delete old map folder from tomtom , then paste new map to tomtom.
    activate new map with fast activate
    Nov 2010
    Hi taximan I don't subscribe to any services, well not yet anyway
    Feb 2009
    thanks guys.... nice one.....
    Dec 2010
    Default Thank you !
    Taxi, Amazing tut.... I got lost with this and usually i can nail things like this. Of all the tuts, the was by far the easiest to follow with great results.
    Well done
    Just one quick query, when I connect to home, i get some message about incorrect device application etc. is there a way around this?
    My old TT one v4 is now running boot 5.5122, map uk & ire 860.3101 version 8.410 and is working well with cams etc.
    Just the home application throws out the error? I tried to the use the easy activator but it keeps saying can't find home. Any ideas would be appreciated.
    Thanks again though
  13. #13
    super jumbe's Avatar
    Livingstone
    Hi Taximan
    Any clue to tutorial how I can update my old Navman?
  14. #14
    Nov 2008
    dekd1
    if you just close the error message, then everything else should work, like update & map share.
    the only thing that won't work is operate my go.
  15. #15
    Nov 2008
    sry super jumbe i have no idea how to update a naviman, i only use tomtoms.
  16. The Following User Says Thank You to taximan For This Useful Post:
    rexbomb (4th February, 2014)
