Results 1 to 12 of 12
    Dec 2010
    Default BMW E38/E39 IKE Bin files needed
    Does anyone have the BIN files for an E38 or E39 instrument cluster? I have a 2001 and need the following.
    IKE_eep.bin and IKE_EEP.wr
    Mines have corrupted and I have erractic guages now. I have the 93S55 chip, SW 13
    Land of Rocks
    Quote Originally Posted by velvetj69 View Post
    Here you have it.
    Apr 2016
    Default cluster m3 e46
    Quote Originally Posted by tachonow View Post
    Here you have it.
    hi, i need ike_eep.bin and ike_wr.bin for cluster with sw 11.0 and hw 12.0
    thanks so much
    Jun 2016
    Would this be the same file for a 2005 e53 x5? or does anyone have the files for an e53 x5? reason being is I have eeprom check sum error. I have 2 main problems, one being that the outside temp sensor works, Ive tried 4 sensors and have another e46 ive tested them on, knowing they all work. but as soon as the x5 hits 90 degrees out the cluster jumps to 122 and then turns the check engine light on. Wiring is good and not shorted, ambient temp sensors work on the e46 and work at anything below 90. I believe it is the corrupt eeprom check sum in the IKE causing this issue... the other is i need to remove some facotry coding on my x5 because the air suspension was removed.. this is not causing any trouble right now but it i couldn't get NCS expert to work for the same eeprom check sum error reason...
    Aug 2016
    Posting to enable file downloading :-)
    Feb 2018
    I need HW 24 SW 21 could be possible?
    Thank you.
    Jul 2019
    Thank you for the files
    Apr 2017
    Hi, I need bin files for e39 525i/530i cluster 93s66 eprom is there someone who could help?
    Nov 2022
    Also trying to download this files
    Sep 2023
    Here you have it.
    thank you very much
    Sep 2023
    Thanks you for your help
    Mar 2025
    Thanks for help!
