Results 1 to 15 of 19
    marcolr's Avatar
    Default Seat Toledo 1999 need immo off
    Hi mates, I need immo off in a Seat Toledo 1.9 TDI year 1999.
    I tryed with Vag K+CAN commander but not communication with ECU.
    I have dump of dash eeprom 96c66.
    I don?t know what I need to override the immo.
    The problem is that the car has failed several times to start and have to make several attempts. Then I prefer to override the immobilizer to avoid problems.
    As I read I have to remove the ECU and I think inside is a 24C02 eeprom and I have to change data in it, but I don?t know how to change it.
    Can not be overridden the immo in the dash? Always must make it in ECU?
    Data from the ECU and Dash are:
    Address 01: Engine
    Control Module Part Number: 038 906 018 BT
    Component and/or Version: 1,9l R4 EDC 0000SG 2130
    Software Coding: 00002
    Work Shop Code: WSC 00046
    VCID: 69D2BFFA7F23F454
    Address 17: Instruments
    Control Module Part Number: 1MO 919 880 R
    Component and/or Version: S5-KOMBIINSTR. VDO V13
    Software Coding: 04140
    Work Shop Code: WSC 03726
    Additional Info: IMMO-IDENTNR: SEZ7Z0W0006196
    VCID: 62C0A8D68215A70C
    Thanks in advance
    mexanico1971's Avatar
    portugal
    ei ! put the dump of the ecu here !
    I not shore but maybe 24c02 !
    put the numbers of hw and sw like 028xxxxxxx 103xxxxxxx
    umoussa's Avatar
    Universe
    Mate,
    It's 24C02 as you said, post your dump here and gladly i will be helping you with that issue
    Thanks,
    ECU Commander Studio?
    Hand in Hand to Protect our Efforts - Stop Hunting Our Work
    >>>>>EBAY SELLERS<<<<<
    I'm not Sharing Passwords!
    Do not argue with an idiot. He will drag you down to his level and beat you with experience
    marcolr's Avatar
    Thanks for your responses m8. I don?t have now the car here.
    As soon as I have the car I dissassembly the ECU and post here the dump.
    H.Wessel's Avatar
    This car is Inmo2, it hasn?t got inmo at ecu, only at dashboard
    Dashboard eeprom maybe 93c66 or 93c86
    H.Wessel
    marcolr's Avatar
    Quote Originally Posted by H.Wessel View Post
    H.Wessel
    Yes, it?s immo 2 and eeprom os dash is 93c66 and I have the dump.
    But how to override the immo?
    I had read many posts and I see that everybody make off immo in ECU.
    I just made a couple of tests with the K + CAN commander in supported cars with EDC15 ecu and is very easy, just press a button that says "Immo off" but really I don?t know what changes made in data eeprom and I think that only supports 24C04, but not 24C02 that I think is the one with the ECU of this Seat Toledo.
    umoussa's Avatar
    Universe
    H.Wessel
    It has Immo in the ECU of course, but it does not have PIN
    >>>>>EBAY SELLERS<<<<<
    H.Wessel's Avatar
    Quote Originally Posted by umoussa View Post
    I think you are wrong because when you change an Inmo 2 dashboard you only have to program the keys with the new dashboard and you don?t need to program the new dashboard with the ecu first,like inmo 3 cars
    marcolr's Avatar
    Hi m8,
    Here is the dump of 24C02, can someone make Immo Off for me?
    BOSCH 0281001926
    038 906 018 BT
    marcolr's Avatar
    Please someone can give me immo Off?
    Thanks in advance
    is very simple my friend you can just do adaptation whith vag com 01 engin
    10 adaption
    canal 00
    test sauve
    and all is ok
    DK Veteran tomaszcz's Avatar
    ZGP
    Quote Originally Posted by marcolr View Post
    Hi m8,
    BOSCH 0281001926
    038 906 018 BT
    Try this file.
  13. #13
    marcolr's Avatar
    Quote Originally Posted by kool_mi View Post
    10 adaption
    canal 00
    test sauve
    and all is ok
    I don?t make immo off never, but it?s the first time I read that vag-com can be immo off.
    I only make immo off by K+can commander for test and it works in some ECU?s but not in all.
    In that case K+can commander not read the ECU and I can?t make immo off.
    I read many posts in this forum and I think need modified 24C02.
  14. #14
    marcolr's Avatar
    Quote Originally Posted by tomaszcz View Post
    Try this file.
    Thanks mate, but how I say you by PM I need the car ok before 17:00h.
    I found a file at net and reprogram my eeprom with it and car works ok with immo Off.
    I don?t understand, because your file and mine are differents.
    Look the file that I found.
  15. The Following 3 Users Say Thank You to marcolr For This Useful Post:
    drix2006 (7th November, 2018), kreepyme (17th September, 2016), rsologubov (11th May, 2017)
  16. #15
    Dec 2012
    Red face thanks
