I'd like reported the successful use of tweezer method to SL96-9 in X2 Xantia 1.8 16V 1998 thanks to information from this forum. I used tweezers to two longer sides of flash memory, ie those with 9 pins. Sides with seven pins each include a power supply pin, which I feared short-circuited. Thank you for all the useful information.
Hello
I need file immo off - TMS374 with 29f512
Sagem sl96.
TMS 374.rar
Hello , hi need solution for SL96 To test bench and know if it is immo , I do not have the car, and I want to know before sending the ECU if it's okay
Dont Forget To Leave ThanksAlegria Chiptuning
Si tu rentres en diagnostic sur table, c'est que l'immo est d?verrouill?.
CentralinasPt (2nd December, 2016)
Yhoni (24th November, 2024)
To establish diagnostics on table You have to follow those steps:
1) connect power and grounds for SL96
ECU pin 13 and 35 connect to +12V
ECU pin 36 and 54 connect to GND
K-LINE from diagnostic tool connect to ECU pin 12(L-Line) and pin 31(K-Line)
2) do not use AUTO ID on Your diagnostic tool !!! - this feature going to establish connection with BSI but You don't have it on Your bench - so choose car model/engine manualy!!!
if You made immo off properly - you will establish communication with ENGINE ECU
if You can't connect to ECU - check wirring and make surre the car and engine code You want to connect is the correct one. If problem exist - probably You are not in IMMO OFF MODE - keep trying Your immo off solution once again
The previous post is from January 2017.
I hope that since he does not wait for the answer!
Le post précédent date de janvier 2017.
J'espère que depuis il n'attend pas la réponse !!!
Thanks a lot
can anybody please help to me with disable immo.
SL96
21649800-5
Ind. Mod E
9176333157
inside is 29F010A
Many many thanks.
And have a nice weekend.
No adverts in sigs mate
Who to read ? It
Sent from my CPH2113 using Tapatalk
How
