Vivid 10.5 is FAKE !!! Doesn't exist !
Do not download from the web ! Waste your bandwitch and money !
i have the same problem with vivid expiry can anyone help
First of all. Version 10.2 works fine with easy file changing. You don't need to use crypt key and all that staff. Even if you did something wrong.
Ask on PM for some help.
If I could help just thank...
Hello
Vivid Workshop 10.5
vivid 10.2 crack tutorial for those of you who have been having problems getting it to work pm me if you need link as DK rules state no posting of torrent sites
Install and just copy the .DLL from crack folder .
to C:\Program Files\Vivid WorkshopData ATI folder but you have to change properties of dll.
right click properties Set it to read only but after you copied it.
You need to enable your hidden files/folder.
Tutorial is here - How to View Hidden and System Files and Folders in Vista | Microsoft Vista | Tech-Recipes
folders_in_vista/
After that you will see that folder in C:/
Before run delete all files in:
XP: C:\Documents and Settings\All Users\Application Data\WorkshopData\48\
Vista/7: C:\ProgrammData\WorkshopData\48\
Now it should be all working ok!
I have installed 10.2 but I having the problem with the 0 days.
Can anyone help me with a good crack ?
I have the program installed on Windows 7!
Have you tried to un-install and try it again to install and see if it helps..........I had a same problems and the this trick worked for me....
Thanks Ash
Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
I got it to work ok on desktop(winxp) but just cant get it to work on laptop(also win xp) which I use at work, have deleted and retried 2 or 3 times.
Make sure it is disconnected from internet during instalation
Can somebpdy tell me how to activate the printing function in Vivid?
wot happens if u put your pc clock back 1 year ?
