Any progress with the FLS. editing?
So two 6NZ motors will have the same flash file? When I look on ET some have a variable torque while others have a set torque. Can I copy one of these ECM flash files and reload it on another truck? i have Cat ET 2011B Dealer version. I assume then that I also need some key when I try to copy the flash file?
Yes, after you copy the new flash file into the ecm, the engine will start but the CEL will be on and you will have no throttle.
if you look in your parameter screen, you will see that your personality module will say not programmed. click on it and another window will pop up showing you what you are changing it from and what you are going to. it will give you 2 coded lines or codes and you will have to get 'factory passwords' in order to finish the flash.
you will need access to a factory keygen
you should always copy your original file before starting to flash. This way you have your original file if something happens during your flash.
hope this helps.
hj everyboby
who konw change injectors C15 giude with me becuase 06 injectors bad no working. I change 06 new injectors
5A500168748B
5A5001686690
5A50016869BD
5A5001688054
5A5001686797
5A5001688646
but i no kown change injectors where?
By using tools which read directly through the back door but any progress on fls editing ? This is Adem4
mang5087 (10th July, 2013)
no. only read and write eeprom and ext flash
so afther reading a4 e3 controller from a lee c13
whit a 40 euro ebay tool and a software to make 3d mapping
whe direkt see all fuell maps timing maps etc everyting so tuning a ecm like this is no problem......
if people realy intrested im open to help were i can..
just send a pm,
mang5087 (2nd April, 2013)
I will try to shed some lights to this thread. I have been tuning Perkins engines for some years, and Perkins use the same ECM as Caterpillar.
Forget all this about Master ET and flashfile editor. What you need to do are reading out the binary file from your ECM, then edit this file and write it back to the ECM. For reading and writing/programming you will have to use a BDM tool, because this ECM's have a Motorola MPC5XX processor. There are several suppliers of BDM (background debugging module), I personally use BDM100 made by EVC. For reading and programming you will have to open up the ECM. The file you are reading have to be edited by WinOLS. This is a licensed program made by EVC. There are some crack out, but beeing a pro tuner I work with licensed software. You will also need a plug-in to handle the checksum for WinOLS. The BDM100 will read the whole content of the ECM, and not only a partial read. With this feature you can also make a clone of an ECM, or even virginise. There are now lately launched tools from other manufacturer that can flash bin files directly to the ECM without the need for opening, this is the KessV2 made by Alientech. This is very handy when you already have the file readout and just want to make a quick correction, and you can then do so directly through the diagnostic connector. With these tools you can edit and release the hidden power of your Cat or Perkins engine. Editing the files are the real job, and require a lot of experience and testing. Good luck.
amishmafia00 (12th February, 2014), GoodPuppy (11th June, 2015), HISPEED428 (18th January, 2020), mang5087 (31st March, 2013), r.kelly (31st March, 2013), SaMirakle (31st March, 2013), servando (25th October, 2017), squirles (31st March, 2013), TjGill (8th January, 2023), toshor (31st March, 2013), whalla (4th June, 2015)
New Genius also supports writing bin but kess/genius cannot read. You still need an ori reading for that software version, make mods and then write. BDM100 is a nice tool.. I use Trasdata as well.
Is it possible to just use a BDM to simply clone an ECM? I have a tuned one that's dead and I have a BDM100 but have no idea how to use it.
