Results 1 to 13 of 13
Thread: Texa software
    Europe
    Default Texa software
    Hello guys.
    I have a Texa Software, IDC3 tribox mobile, and about diagnostic is very good and complete. It allows to do some sort of telemetry, gives the value of a lot of parameters (air mass, water tem., etc) in function of time in graffic presentation too. Is very usefull for immo, engine ecu and cluster stufing like reset, program, etc.
    I only have one complain, the support sucks, mainly here in Portugal. I bought it 3 years ago and when i have a problem or doubt (it happened 10-15 times) i call for suplier and nothing...just have to do by myself.
    Some time ago i bought a spare ecu, an ME1.5.5 for an Opel Corsa Z12XE engine for doing some experiments. The ecu didn t came reset, and bring the security code allong with.
    I tought that could manage that with my texa soft, by i cant.
    First just tried to reset and program ecu, the immo light keeps blinking.
    Then tried to reset immo too and adapt do engin ecu, same problem, immo light blinks.
    What i want to ask is if someone tried something similar with this kind of soft and give me a clue if is possible to reset this ecu (i think it is) and what am i doing wrong.
    Thanks a lot.
    Oct 2008
    Greece
    Talking
    Quote Originally Posted by serbar View Post
    Hello guys.
    Thanks a lot.
    Well, at LEAST for Opel - Vauxhall ECU's = STOP to "Dreaming" about Resetting - Virgin - Programming with ANY of kind about those Tools - Software's!!!
    X-Mas Regards!
    Europe
    Thanks Patrian.
    You see, i think i can do it because i can reset my original ecu with texa (at least cant start the engine after reset and the immo light starts blinking). And then program too.
    So that just leaves two options:
    1. Cant reset engine ecu in a diferent car from original;
    2. The ecu is damaged.
    About the second option i don t believe much on that because at least i tried experimenting actuators with texa (ignition coils, injectors, fuel pump, relays etc) and all works ok.
    Some more ideas please?
    Thanks.
    drakov's Avatar
    Aug 2008
    I am sure you must reconnect ecu to original car and reset first before transferring to donor car, also you must reset ecu in donor car then I believe reset/reprogramme various other modules/controllers for this I don't think texa has capapbility
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
    obdmaster's Avatar
    Never never land
    Thumbs up
    Quote Originally Posted by drakov View Post
    You can reset donor opel ecu, in different car even if you dont know security code . By using opel pin reader by nasratech or abrites opel commander with special functions.
    Hope this helps m8
    You need every tool in the book, to do this auto locksmith job.
    Europe
    Ok.
    Thanks guys. Will see what i do.
    By the way obdmaster, do u know if abrites or pin reader by nasractech have capability to read and write eeprom content via obd on this ME 1.5.5 ecu?
    Thanks.
    obdmaster's Avatar
    Never never land
    Thumbs up
    Ok.
    Thanks.
    I know nasratech one you cant as i use that one.
    The abrites version looks like you can m8:
    Can i ask why you would want to?? Is it to clone an Ecu??
    ON002 Opel/Vauxhall Read Security Code & R/W EEPROM Function - Opel/Vauxhall - AVDI & COMMANDERS
    Europe
    Thanks a lot obdmaster, thats what i am looking for.
    I am trying to do a complete understanding of this ECU, including disable immo by myself. But my real aim is to remap this one. The spare ecu i bought is just for caution and to have two if i do something wrong.
    Thanks.
    Could someone Texa IDC3 31.0.0. keygen or activation code
    Europe
    Hello guys.
    I emailed Abritus asking if this tool ABRITES Commander for OPEL/VAUXHALL 3.4 could read/write eeprom on ME 1.5.5 ecu.
    They answered its not possible.
    I ask if some of you, forum users know some method to enable disable immo on this ecu.
    Thanks for all replies.
    Junior Member cirkalo's Avatar
    Hello everyone. It would be asked single TEXA IDC4 seria 41,22 pluses a dongle hasp key. Thank you
    Croatia
    please help me!!!
    I need Activacion cod (my code is 35A0BEE031624FDE47D843C3) for Texa idc3 ver. 31.0.0 car plus
    Thankes
  13. #13
    Nov 2010
    Quote Originally Posted by linkic View Post
    please help me!!!
    Thankes
    Where on this forum did you see someone who posted an activation code ? It is possible only Texa Dealer !!!
