Results 1 to 10 of 10
    Nov 2010
    Germany
    Default VDO D43 dump (Audi A8) - how to decrypt?
    Hi. Here's a VDO 882SX D43 dump from a 1999 A8.
    Does anyone have a tool for me that could decrypt it, or know anything about the type of encryption used? I'm not trying to change the odo or anything, I'd just like to understand how it is scrambled. A decrypted dump would also be appreciated.
    Also, can someone get the PIN from this dump?
    V.I.P. Member milanoffracing's Avatar
    Bulgaria,Sofia
    Quote Originally Posted by SundayNightDriver View Post
    PIN from your dump is: 14134
    Nov 2010
    Germany
    Thanks. Hm, that's the cleartext value at 0x7bc as big endian.
    I don't think it's correct, it would have to be decrypted first, and login codes for this kind of cluster+ecu should be 4 digits plus leading zero. VW will generate a 7 digit SKC from it with date + dealer code.
    edit: I found an uncrypted dump of a similar cluster, and it has a decimal value <10000 at this spot.
    The problem is that the D43's eeprom is encrypted.
    Nov 2010
    Germany
    The correct PIN for this dump is 8004.
    And it seems no one can decrypt it..
    Sep 2013
    Any news about this odometer how to decode this file?
    Wysłane z mojego GT-I9506 przy użyciu Tapatalka
    Sep 2013
    [QUOTE=adrian1914;2616863]Any news about this odometer how to decode this file?
    Nov 2011
    Macedonia
    This file is not crypto ..........................
    Baze007
    Sep 2013
    Can You help me to extract pin from this dump? Ill try all my programs but it can?t
    zckariya70's Avatar
    Jan 2014
    Inside EEPROM
    Quote Originally Posted by adrian1914 View Post
    In this odo km is 347160 PART NO:- 4D0 919 882 SX D44 PIN:-65492
    Nothing will remain in this World , Everything will come to END!
    THINK POSITIVE NOTHING IS IMPOSSIBLE
    Please do not spam by PM asking for help. Use forum, that is why we are here.
  10. The Following 2 Users Say Thank You to zckariya70 For This Useful Post:
    adrian1914 (12th October, 2015), DashProg (12th October, 2015)
  11. #10
    Sep 2013
    Is not correct pin. But I menage to extract pin from ecu.
