Results 1 to 5 of 5
Thread: sid 801a 93c56
    busaman's Avatar
    suffolk uk
    Default sid 801a 93c56
    has anyone tried swapping eprom 93c56 on sid801a common rail donor ecu or is there more info stored on the 29f400 to make it work.
    7.31sec@203.3mph
    Member nikinik's Avatar
    Haskovo,Bulgaria
    Default yes
    hi mate!
    i made this few times.it work.after solder to second hand ecu eeprom from original one ,must use PP 2000 or lexia to lerarn keys again.after that must be fine.
    plese report! and if works use TNX button!
    regards!
    busaman's Avatar
    suffolk uk
    Quote Originally Posted by nikinik View Post
    hi mate!
    regards!
    ok i will try do i need to swap 29f400 flash or just eprom.
    7.31sec@203.3mph
    Haskovo,Bulgaria
    Quote Originally Posted by busaman View Post
    only eprom mate!
    unu's Avatar
    Oct 2010
    EUROPE
    only eprom mate!
    only eeprom . If you have possibilities to swap flash contents then is "more safe" for your work.
