Results 1 to 15 of 22
    super jumbe's Avatar
    Livingstone
    Default Nissan Almera start problem
    Hi Mates
    I have a Nissan Almera w reg Petrol.
    Car was running brilliant, only yesterday I was driving along when the engine stopped running while during I have diagnoses the engine and it was telling me the crank and camshaft sensor faulty, any way I replaced both sensors the car still want start, I have found out that no spark coming on the spark plus, can any one help me out could it be the ECU, thanks for your time.
    check all the fuses to the engine bay....if there is one burned you have problem to the iac.....idle air control......i have this problem to with a car to my garage now
    Meat-Head's Avatar
    we had one, when hot came up P0340 - had new lumpystick sensor - ecu was uploaded to ecutesting.com repairs, downloaded, plug and play
    HTH
    Meat
    DK Veteran teuton's Avatar
    Mexico
    Might wanna look fot the circuits of cam- and crank sensor. Do you get rpm reading on scanner while cranking?
    Yesterday we stood in front of the abyss. Today we'll move ahead.
    If you need any repair manual, pm me- maybe I can help you.
    Livingstone
    Thanks for quick reply mates I have been told bad news from an electronic tester he did a quick text, it?s the ECU, this person connected live wire from sensor coming from ECU and the car started but I need an ECU he told me being an old car go to the scrap yard and get the ECU kit the kit includes the ECU, immo box, new keys with ignition lock the cheep way to solve the problem. Any with a better idea to save money I will be very great full otherwise off to scrap yard in the morning.
    Ashraf6119's Avatar
    UK
    Quote Originally Posted by super jumbe View Post
    If his 100% sure its the ECU at fault than also I think going to scrap yard is the best and cheap option for you.
    Ash
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    Sep 2008
    dont know if any good,maybe worth an email.
    Nissan Parts - Buy Nissan Parts from The Nissan Parts Gateway
    racin-snake's Avatar
    Jun 2009
    did you look to see if timing chain was slack due to a bad or stretched timing chain
    what engine size is this ?
    as the 1.8 has vvt so can lock the cam in the advanced position ?
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
    Dec 2010
    if it the N16 Almera they do suffer from stretch timing chains on the 1.5l and 1.8L petrol ones and also they suffer broken wire problems down by the radiator battery side lower xmember area, very rare to have a ECM go down on one them tho, it is poss to get secondhand ECM coded to your vehicle tho you just have to recode the keys if that is the fault.
    drakov's Avatar
    Aug 2008
    My first thoughts would be to remove cover and check to see how much timing chain tensioner is protruding anything above 13mm will give this symptom, although the hotwire fix does tend to suggest ECU fault, if you search for almera non start on dk you will find a thread about similiar where cjawihar posted a quick test to confirm.
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
    Autotecno2006's Avatar
    HI all, we have just finished fitting timing chain to 2001 Almera 1.5, which had same problems as urs. When chain slackens more than 10mm the ecu picks up the sensors as being faulty. Check That Chain !
    DK Veteran Albanais's Avatar
    Tirana
    Quote Originally Posted by Autotecno2006 View Post
    I will check the chain too. If the chain is extended as mates told previously, because if it is so then it will be useles changing the entire injection system, you will not solve the problem. If vehicle has more then 100.000 km I will go sure straight on it and check it. Good luck mate.
    Learn from the mistakes and live the life.
  13. #13
    Livingstone
    Hi good morning all.
    Thanks all for the help, I personally thought it was the chain but I did realise that if it would have been the chain the car do start with engine not having the power but this one it just do not have the current coming to the plug leads and the auto electrician checked that it the ECU, any way to cut the storey short I just rang the scrap yard he is asking for the full kit for ?90.00 if I take them out my self, thanks mates I am off to scrap yard not a very bad day today anyway, I will keep you posted what ever happens.
  14. #14
    Tirana
    Okay good news, if you have no spark at the spark plugs is because if you have no synchronization then you will not have sparks for sure, neither fuel, no synchronization not spark plugs. Because of misinformation between the sensors thats why it happens. However hope you will resolve the problem. Cheers mate
  15. #15
    cjawahir's Avatar
    T&T
    check all fuse in engine bay , check the positive wire on coil pack , if you dont have power there fuse is damage .
    if this fuse is damage disconnect the iac valve and start .
    cj
