Results 1 to 5 of 5
Thread: DM 600 PVR
    Jan 2011
    Default DM 600 PVR
    Well...dont know where to start! I have dreambox from today and wanted to install the new image ...is start fine but when needed to restart dreambox stop! I try everything but no reaction! There is two small lights in front of receiver(the place where receive the signal from remote) red and green and they are flashing without stoping but do not recognise signal from remote and can not connect with PC to install again!!! I do not know what is wrong!!!!!!Need help!!!!Hope..to !!! Thanks!!!!!!!!!
    DK Veteran piopat's Avatar
    May 2008
    did you flash the box your self ? ,did you use dreamup and a null modem cable ? ,or are you using a usb to serial adaptor with a null modem cable . did you buy the box new today ? ,did it come with the image on it and all you did was plug it in ,we need as much info as you can give .
    i love it when a dreambox comes together.
    Jan 2011
    Default DM 600 PVR
    Hello!! Well DM 600 PVR is my new box with factory installation something like enigma etc.! I`m not sure (I think that is original) is it original or clone!? Anyway I did try myself (did many times with triple dragon) to install the image evolution with lan and flashwizard so everything was going fine utill should restart automatically! Then the box is stop and dark!!! Only you can see two small lights in front of dreambox (the place where receiving the signal from remote) red and green flashimng fast without stoping! Dreambox could not be connect to PC or TV or anything else only two small lights! So my friend what to do? I find out that the evolution image is not for DM 600 PVR , that means I put wrong image!! Now how to return dreambox in normal situation!? You can tell me which image is the most stable for DM 600 PVR!! I like dark ambient music and horror movies so is there any images on that way!? I`m new boy to dreambox so do not know much about images,plugins,etc.!! Hope you can tell me what to do!!!! Thanks anyway and big greetings!!!!!!!
    May 2008
    you will have to try and reflash the box and you will have to use dreamup and a null modem cable (a usb to serial adaptor may not work) if your pc does not have the correct 9 pin connection for the null modem cable you wil need to find a friend or some one who has a laptop or a desktop pc which has a 9 pin serial connection . you can download dreamup 1.3.2.1 and a good nabilo dm600 image from link number 4 in my signature area. i recommend you try a flash erase ,when you open dreamup look above where you see flash and you should see flash erase (if so click on it all it takes is seconds) if you have flashed more than once click on flash erase again.
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    have to say mine works great and always has
