Results 1 to 13 of 13
Thread: RENAULT MEGANE2
    Jan 2011
    IASI ,ROMANIA
    Question RENAULT MEGANE2
    i have a problem with an renault megane 2 1.6 l 16valves gasoline year2002 always set the p0010(intake camshaft position actuator circuit/open bank1)and p 0340(camshaft position sensorAcircuit malfunction)The circuits and the sensors are checked there is no problem.The inlet phase gear was changed because was very noisy and the timing kit was replaced.All the tools for inlet phase gear and timing was used from local Renault dealer and tehnical information from Dialogys.I check again the timing to be sure thre is no problem and is ok .If the codes are erased, after the engine is warming and is partial load the codes appear again .Have anyone a ideea what can i do with this problem?
    DK Veteran Larue's Avatar
    Somerset, UK
    First of all You should read forum rules Mate! We don't mind to help You, but You should introduce Yourself first!
    About Your problem..... if You have access to dealer information....just check for software upgrades from Renault. If I remember right there were some software upgrades for this thing....If wiring is OK, Cam sensor and activator is OK there always possibility of broken ECU, but check for updates first.
    Cheers!
    Ashraf6119's Avatar
    UK
    The Cam Sensors are very common faults on this models so i would replace one and see......... as for the Cam Actuator it has a two pin connector take a very small Screwdriver and tighten those wire clips very common again they get lose and cause poor connection to the Actuator Sensor, you can also try for the Cam Sensor plug same thing before replacing another sensor.
    Hope this helps..
    Ash
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    Portugal
    Hi friend.
    Where the timing belt is mounted there are a point that normally gets out of the place, it advance a little bit.
    You are using the correct tools but if it is already advanced you are stopping the motor a little bit out of place and you think it is on the right place.
    Normally this situation causes de car doesnt start at first time and starts at second time you turn the ignition on.
    Regards,
    Nuno
    Jan 2011
    IASI ,ROMANIA
    Default megane 2
    i understand but the car starts normaly ,there is no problem,when the engine is cold don"t set any code visible on instrument panel (if i put the scanner i can see the codes without the "SERVICE"light on)and when i driving the car there is no diference in functionality.I check the wiring diagram and the sensors ,everything is fine on the car.Always the trouble codes says me that the camshaft actuator is open circuit and the camshaft sensor read "missing teeth".Thanks for your atention!
    Liteace's Avatar
    Mar 2009
    On a rock
    What the condition of the engine oil and is it the correct oil grade, could be ok when cold & thick but not doing it job when its hot and watery, Scope the cam control solenoid valve to make sure your getting no glitches, if all else fails burn it, ~~~~~ing renaults
    Ashraf6119's Avatar
    UK
    Quote Originally Posted by gabrielandriev View Post
    Replace with new Cam Sensor and all should be OK............ Trust me its Renault a French Baby
    Ash
    Thanks Ash
    Member DCD's Avatar
    Gloucestershire
    Check cam sensor signal pattern with scope if NG replace sensor. If sensor fault returns there is a injection computer reprogram avalible to update software, this will stop fault returning.
    Jan 2011
    IASI ,ROMANIA
    Wink Renault Megane 2
    THANKS to all of you for help.I fix the problem with a new camshaft sensor exactly how some of you sugested.I ask the local dealer Renault and when you change the phase gear on inlet camshaft you dont need any upgrade of ECU software.Once again thank you for your support.
    Liteace's Avatar
    Mar 2009
    On a rock
    Thanks for the update
    Ashraf6119's Avatar
    UK
    I am glad that you have sorted this one.........But, how come you did start new post just to give us your feed back.....Why you didn't post in your original post
    http://www.digital-kaos.co.uk/forums...egane2-185050/
    Any good reason...........
    Ash
    Thanks Ash
    drakov's Avatar
    Aug 2008
    Merged..............
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
  13. #13
    Ashraf6119's Avatar
    UK
    Quote Originally Posted by drakov View Post
    Merged it from........ A-Road to M1
    Ash
    Thanks Ash
