Results 1 to 4 of 4
    Newbie bidong's Avatar
    Tropical Islands
    Exclamation 1996 Kia Sportage Trouble Codes
    Good Evening fellow garage junkies.
    I would like to ask for some help because I'm currently troubleshooting this Kia Sportage 1996 2.0L diesel with the RF Engine.
    I had trouble in figuring out what the flash codes mean. Most information i see in the web are for K.Sportage Gasoline.
    Any info would be much appreciated. A Service manual would be heaven.
    Thanks guys.
    Member bmotor60's Avatar
    Kia Code Retrieval
    Some 95 and ALL 96 & later models are OBD2 and require a scanner
    Accessing Diagnostic Trouble Codes
    Models up to 95
    When trouble occurs in the main input or output devices, check for the cause using the data link connector (DLC) and the malfunction indicator lamp located in the instrument cluster. Failures of each input and output device are indicated and retrieved from the engine control module (ECM) as diagnostic trouble codes.
    * Locate DLC at top center of firewall and use jumper wire to connect ENG. TEST and ground terminals.
    * On 1995 Sportage models, turn ignition to On, but do not start engine.
    * On other models, start and warm engine, then run at 2,000 RPM for 3 minutes.
    * Diagnostic trouble codes will be displayed as a series of long and short flashes on the malfunction indicator lamp (MIL).
    Trouble Code Interpretation
    The ECM? indicates stored fault code by flashing the malfunction indicator/check engine lamp. Fault codes 1 through 9 are indicated by individual short blinks and fault codes 10 and above are indicated by long and short blinks. One long blink is equivalent to 10 short blinks. The fault code can be determined by adding the long and short blinks.
    Clearing Trouble Codes
    Diagnostic trouble codes may be cleared by disconnecting the battery ground cable for at least 20 seconds.
    Diagnostic Codes
    Kia
    Without Onboard Diagnostics (OBD-II)
    2 Distributor no Signal.
    3 Distributor G Signal.
    7 Fault on SGT Signal.
    8 Mass Air Flow Sensor.
    9 Engine Coolant Temperature Sensor.
    10 Intake Air Temperature Sensor.
    12 Throttle Position Sensor.
    14 Atmospheric Pressure Sensor.
    15 Oxygen Sensor.
    16 EGR Valve Position Sensor.
    17 Feedback System.
    18 Injector No. 1 open or short.
    19 Injector No. 2 open or short.
    20 Injector No. 3 open or short.
    21 Injector No. 4 open or short.
    24 Fuel Pump Relay open or short.
    25 Pressure Regulator Control Solenoid Valve.
    26 Purge Control Solenoid Valve.
    28 Solenoid Valve (EGR) open or short.
    34 Idle Speed Control Solenoid Valve.
    35 Deteriorated Injector.
    36 Deteriorated Air Flow Sensor.
    37 Intake System Air Leakage.
    41 Variable Inertia Charging System Solenoid Valve.
    46 A/C Cut Relay open or short.
    48 Power Stage Group 1 Malfunction (inside ECM). Injector 1-4 Purge Solenoid Valve, EGR Solenoid Valve or Damaged Power Stage.
    49 Power Stage Group 2 Malfunction (inside ECM). Idle Speed Control Valve Failure or Damaged Power Stage.
    56 Idle Speed Control Valve Closing Coil open or short.
    57 A/C Compressor Input Signal short.
    73 Vehicle Speed Sensor open or short.
    87 Malfunction Indicator Lamp short Circuit.
    88 ECM Data.
    99 Battery.
    Models up to 95
    Diagnostic Codes
    Kia
    15 Oxygen Sensor.
    17 Feedback System.
    88 ECM Data.
    99 Battery.
    DK Veteran RSwire's Avatar
    your girlfriends house
    Check here Kia Global Information System (KGIS)
    It has all the info on KIA it is free to sign up. A little difficult to navigate but it is an excellent site.
    A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
    Please don't pm me for keys, that is what the forum is for.
    If it helped, please use the thanks button, if thanks isn't enough use the scales.
