Results 1 to 7 of 7
    Jan 2009
    Angry error 1611 iphone 3gs restore
    Hi i been trying to sort out my iphone sg3 , during the jailbreak my iphone i update the basband to 06.15 i used redsn0w but when i restart i stucked on apple logon i been searching everywebsite and many shop in leeds to repair it noone could do it, anytime tried to it shows error 1015 , but now it show error 1600, and sometimes 1611, i visited website below and tut below anyone got any idea thanks
    3gs 1015 error fixed successfully - GSM-Forum
    3g,3gs 4.2.1 custom restore Loop fix (Only new boot rom method) 1000% working no BS | Apple Devices Informations
    iPhone Forums - iPhone-Hacks.com / FIXING RECOVERY LOOP WHEN FLASHING 4.2.1
    Restore 3GS to any firmware - SiNfuL iPhone
    many of you have been asking on how to fix 1604, 1603, 1602, 1601, 1600 error in iTunes during firmware restore. This error is occurred when you are trying to restore your jailbroken custom iPhone 3.1.3 .ipsw file
    To get around this problem, there is a handy little tool called iREB (iTunes Restore Error Bypasser) for Windows which can help you bypass the error when you are restoring .ipsw file in iTunes. The latest version of this program works with iPhone 3.1.3 firmware running on the original iPhone, iPhone 3G and iPod touch 1G/2G.
    Follow the steps below to bypass this error so that you can restore iPhone 3.1.3 firmware in iTunes.
    Step 1: Start iTunes and put your phone into DFU mode:
    Press and hold the Home button and the Power button at the same time. After exactly 10 seconds release the Power button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode. At this point your iPhone/iPod touch screen will remain black.
    Step 2: Now close iTunes and Start iREB on Windows.
    Step 3: Simply select your device and wait for a few seconds until you get white or a red screen on your iPhone or iPod touch.
    Step 4: Now open iTunes and select your phone from the sidebar in iTunes. Now press and hold left ?alt? button (?Shift? button on Windows) on the keyboard and then click on ?Restore? (Not ?Update?) button in the iTunes and then release the ?Shift? button. Select a custom .ipsw file and restore it.
    That?s it! iTunes should now be able to restore your iPhone or iPod touch to the latest iPhone 3.1.3 firmware without any problems. Hopefully you wont get any errors this time around!
    One thing to note here is that iREB is not for jailbreaking. It is only used for restoring to custom .ipsw firmware files via iTunes without any errors.
    There are 2 methods you could use. The TinyUmbrella method or the hosts file method. 2 things you will need for either of these methods: The firmware IPSW file for which you want to restore to and putting your iDevice into DFU mode.
    TinyUmbrella Method:
    -Download the firmware IPSW file from the link above
    -Connect your iDevice to your computer
    -Open up TinyUmbrella if you have it, if not, then go here to download it -- If you already have the latest version of TinyUmbrella, than connecting your device is not needed anymore
    -Click the device under "Connected Devices" (or "Recent Devices" if you don't have your device connected)
    -On the top of the right side, you will see "Save SHSH"...click that and TinyUmbrella will save ALL of the SHSH blobs that your device has on file with Cydia.
    -On the left-side menu, click "Show All SHSHs" to make sure you have the SHSH saved for the firmware you want to restore/upgrade/downgrade to.
    -Assuming you do have your SHSHs backed up, click "Start TSS Server" on the top of the right-hand side
    -Put your iDevice in DFU mode (Click link above for intructions on how to do this if you're not sure)
    -Once you've done that, then go into iTunes and Shift+Restore, find the firmware IPSW file you downloaded and click ok
    NOTE: You might get an iTunes error 1015, 1013, 1011 message but that's normal. The restore was successful, just use TinyUmbrella to kick it out of recovery mode.
    Hosts file method:
    The hosts file for Windows is found at C:\WINDOWS\system32\drivers\etc and is called "hosts".
    The hosts file for a MAC is found at /private/etc/ and is called "hosts".
    Go into the file and open it with a text editor and add the following line to the bottom:
    74.208.10.249 gs.apple.com
    DK Veteran fijiman's Avatar
    Oct 2010
    Wales
    Not sure what the problem is....if you found the fix to your current problem....have you tried following the tutorials ..?
    Apr 2008
    Quote Originally Posted by fijiman View Post
    try using ubrella
    V.I.P. Member mickydibble's Avatar
    Nov 2008
    modsvilla
    hahaha fijiman this is piss funny....!!!
    look guys this is old news really, though thnx for your copy n paste form another site....i was in stitches LOL pmsl
    GOOD WORK THOUGH......thanks for joining DK
    Jan 2009
    Quote Originally Posted by sj5301397 View Post
    try using ubrella
    yes i did use tiny umbrella, also ireb, recboot, and visited every possible website and tutorial but no chane it keep show error 1611
    Nov 2008
    modsvilla
    have you tried doing it again? did you stop the process before it flashed the ipad firmware....have device plugged in and try to break out of recovery anyway you can try put iphone into dfu http://www.digital-kaos.co.uk/forums...d-touch-57320/ try opening itunes first as well then plug iphone in...
    Jul 2011
    manchester
    hi, i have just uninstalled itunes 11, downloaded itunes 10 and it wont start says somthing about a file was created by a newer version of itunes, how do i clear all files to use itunes 10. i need to downgrade ios from 3.3 to 2.0 using iREB to try and fix no wifi issue on ipod touch 1st gen. thanks for any forth coming help
    the file i tunes libary 2012-03-17 .itl cannot be read because it was created by a newer version of itunes, does any one no how to get around this thanks.
