Results 1 to 15 of 29
    Jan 2011
    Default Eberspacher diagnoze interface
    Hi all!
    Did have anybody a working schematic for EDiTH (eberspacher diagnoze software) ?
    I build many without success.
    So I use Edith and put an O-scope to serial port (com1) and wach the signals, I realise there is two mode that Edith is useing the interface. In one mode togeling the DTR (4) signal and than togeling the RTS (7) signal 3 times (while EDiTH says "Activateing diag") after that is "listening" on RXD(3) the signals from the heater. This is the mode that is use the most of the heater and this mod is not working for me .
    The other mode is a simple K-line interface where is useing the rx and tx lines to send and recive data. This mode is working but only the 1/4 of the eber heaters use this protocol.
    So i think the schematic has to look like two "TX" lines ( RTS 7 and TX 3) swiched useing the DTR signal and an recive RX (2). And ofcourse the level change circuit (max232 and transistors or opto).
    I build one but without success . I think the signal levels and the inpedance is different on Eberspacher heaters. It not use the 510ohm impedance and the 12V level. (max232 and 7404 with transistors).
    Any info are wellcome.
    According to this site (http://www.blafusel.de/obd/obd2_soft.html) edith should work with kkl interface. But this information seems to be old, since you can only work with some heaters.
    There is a link to some software and pdf's (www.espar.com - /www/espar.com/tech_manuals/Diagnostic Software/) if you not already seen it.
    Sorry, can't help more.
    Jan 2011
    I knew this sites but thanks anyway. You gave me an idea with the KKL interface, I will use only the L line but I have to chang the levels or the impedance. Maybe it uses just only 5V like GM models ?
    What I knew that 510ohm impedance is very low for Eberspacher heaters and it "kills" the RX from the heater. I can recive messages from heater at about 4,7k.
    Maybe you can try to ask ebersp?cher. Since the software is freeware, perhaps they give out informations about the needed interface, too.
    Jan 2011
    They have for sale ISO Adapter for xxx euro. I don`t want to spend thousen euros for one simple adapter because I have 2 heaters one in use other for hobby. I just want to see live data from the heater.
    Jan 2011
    I made some progress . It can be easy read out/erase the codes with a swich+cap and an terminal program (hyperterminal).
    Now I workin on the interface, some timing problems what i will resolve use a microcontroller.
  7. The Following User Says Thank You to eliberatoro For This Useful Post:
    eco019 (30th April, 2022)
    Jan 2011
    Here is the interface what i made. It is working, tested with psa, ford and vag heaters.
  9. The Following User Says Thank You to eliberatoro For This Useful Post:
  10. #8
    Jan 2011
    Here is the link for the complete documentation (eagle pcb and schematic, usb config files, drivers and pic microcontroler program)
    4shared folder - My 4shared
    I added a webasto interface too
    Enjoy
  11. The Following 3 Users Say Thank You to eliberatoro For This Useful Post:
    art64 (15th November, 2013), eric paris (18th March, 2019), girolamodisidisi (2nd August, 2017)
  12. #9
    Junior Member planktom's Avatar
    Nov 2011
    black forest
    hi
    would this interface work with an airheater D3LC ?
    ...and if yes,would you sell such a board or complete interface ?
    greets : tom
  13. #10
    Jan 2011
    Quote Originally Posted by planktom View Post
    hi
    greets : tom
    I do not test on D3LC but has to work with that. This interface is not a copy of the original because it was developed by me, so can have bugs.
    No I do not sell interfaces.
    Try it and post results.
  14. #11
    Nov 2011
    black forest
    thx !
    so i have to try getting someone to built me such a pcb
    as i?ve got no experience building such things
    would you mind if i post your solution eg in the german T4 board
    as they are searching specially an interface for the D3LC ?
    http://translate.google.de/translate...eadID%3D159090
    i hope i can find someone there to build me such an interface
  15. #12
    Jan 2011
    You can freely distribuit.
  16. #13
    Nov 2010
    I am happy that there are people who share such information
    I will try build this interface and test it with Edith, hope it will work.
    Maybe there are any updates?
  17. #14
    In The Dungeon
    Cantiecar device working perfectly with new mode for ebrspacher.
    Tested fully on D4WSC and D5WSC. Timer MUST be disconnected from unit because when activated timer drops power to clear codes for 3 seconds making a timeout occur. Heater must be powered on for diagnosis.
    Thanks to Alexander for his time.
    Tiecar.net
  18. #15
    Dec 2011
    Hello , does someone have EDiTH software to share , please ?
    All links not working
    Best regards
