Results 1 to 12 of 12
    Member tripper's Avatar
    Jan 2011
    collingwood victoria australia
    Default homebrew wii stoped as i did this ?
    i just got the home brew on my wii my son went to the normal place to play the game it asked for an up date it know dont work so where or what do i have to do know to get it to work again the bloody thing just cost me $ 50.00 to get it put on i dont start from the home brew screen there is another one so what do you use the homebrew screen for is that for internet stuff i dont know much abought it please some one help
    tripper
    V.I.P. Member ck-ok's Avatar
    Dec 2008
    nottingham
    Quote Originally Posted by tripper View Post
    did you pay someone too put the homebrew channel on?
    the homebrew channel is for running apps on your wii.
    you should now be playing your backups with neogamma.
    if your homebrew channel is still working then follow this tut http://www.digital-kaos.co.uk/forums...-3-mod-157379/ from the section after installing homebrew making sure you install priiloader to stop it from asking to update
    Jan 2011
    i think i might have to take it back to this ***** to get it done i cant work it out if you could email me the info in righting how to do it would help as i dont know two much i want to find out tho sick of paying $100 for these games only if you can do it i am not expecting it just let me know thankxs again tripper email add glenjessy@hotmail.com
    tripper
    Dec 2008
    nottingham
    do you still have the homebrew channel?
    Jan 2011
    yes dont know what to do tho
    tripper
    Jan 2011
    the home brew chanel is still there & the neogamma when i start it goes black wont load game or what ever site it is where i start my games from i wanted to no will i need the game again to fix it when i try start it just goes black screen nothing happen remote turnes off and cant even go to woo home screen have to power off hey man tank heaps for all your help so far will have to tell more people abought this mad site
    Last edited by tripper; 31st January, 2011 at 01:33 PM. Reason: wrong spelling on some thing
    tripper
    Jan 2011
    and i must be silly the home brew chanel is to use wireless with the internet hey can some one let me know
    tripper
    Dec 2008
    nottingham
    ok you already have the homebrew channel so download the mod pack from here http://www.digital-kaos.co.uk/forums...-3-mod-157379/ then follow this
    format sd card again and extract modpack from the folder you downloaded earlier to sd card
    run md5summer.exe and click verify sums and check theres no errors
    now you need to install your wads.
    Start HBC, press [HOME], Launch Bootmii
    Multi-Mod Manager Starts (via cboot2)
    Never Uninstall IOS, you will brick your wii
    Select "WAD Manager" - Press A
    Press (1) to "Install all Wads" - Press A
    19 wads should install without issue
    "Press any button to continue"
    Be sure all the wads install, very important
    If the wads fail to install, install 1 at a time
    Press B two times- main menu
    thats it nearly finished just need to install priiloader
    You should now be at the main menu of Multi-Mod Manager
    Select "App Manager" -press A
    Select priiloader -press A
    Read the warning- Press +/A to install -if needed Hold B press +/A to install with cIOS
    After priiloader installs, it may freeze during restart- this is ok
    Hold reset and boot wii while holding reset- priiloader will load
    Select "System Menu Hacks"- Press A
    Enable "Block Disk Updates", and "Block Online Updates", others if you like
    If MMM loads at boot, select Manage Priiloader, Edit Priiloader Hacks, enable needed hacks.
    If you don't know what the hack does- you don't need it.
    Your wii should now block Disk updates and online updates
    if you still keep booting to mmm try renaming bootmii to bootmii-old
    Note: Prilloader installer gives two errors-
    /loader.ini couldn't delete error -106
    /password.txt couldn't delete error -106
    this is not a problem just carry on
    thats it done
    Jan 2011
    will i still need Lego Indiana Jones games to do this still just need to know that
    tripper
    Dec 2008
    nottingham
    no you already have the homebrew channel
  11. #11
    Jan 2011
    thats all cool but the home brew channel is working its where i start my burnt games from i cant work that part out i down loaded the stuff put to sd card still no go i think i need some thing else its the neogammer that wont start the games any ideas ould help heaps
    tripper
  12. #12
    Jan 2011
    Default wii neogammer
    i did an up date now it is not working can anyone put me on the right track to get it working again any ideas what to do
    tripper
