    Default EPC error please help
    i have installed EPC and WIS , all work fine and after 2 weeks i get error when i would like open "datacard " :
    "No read authorization for this datacard"
    please can anyone help me ??
    Quote Originally Posted by davor.electronic View Post
    So were you able to read data cards previously with this installation? Is this car from the same market area as others that you can read? Have you looked at your access authorisation settings?
    Quote Originally Posted by DB_member View Post
    i read the data like first time and same VIN number ....
    before are work all fine now not work , not understand where is the problem. Database work all correct but only can't open "datacard" from EPC ... WIS work fine ....
    please help if you know where is the problem
    You have to modify the epc access authorization setting.
    Goto EWA net login.
    Click administration - Group - permission group for the server administrator
    In the EPC access authorization, choose limited access authorization. Click limit access authorization
    Then click update, untick datacard blocked
    Save then save again.
    Quote Originally Posted by pesona View Post
    Goto EWA net login.
    thanks, i will try
    thanks, i will try
    i test and work fine now
