HI I NEED TO READ A 95640 EEPROM, BUT I DONT HAVE THAT CLIP, HOW CAN I READ IT. SOME HELP PLEASE WHAT CLIP TO USE, BECAUSE ITS SMALLER THAN A REGULAR EEPROM. THANKS![]()
U have to use some of those on the pic.
Search forum for micro grabbers. There are several comp. making them. I'm using Pomona ones... not cheap, but works perfect.
WHERE CAN I BUY THE CLIP
google -------- it
We not using CAPS, while chatting... only while yelling ...
Anyways.
Here is the website, where i bought those grabbers.
Datacomtools, brady printers, butt sets, cable testers, utp cable testers
Just put "6351" in the search box...
U will see them.
Cheers
i just want to add that thess clips are good but they brake very easy,depends on use, i bought some from
Andromeda Research.they are more stronger then these ones and less expensive as well
thanks a lot ,half price, EPROM PROGRAMMER DEVICE PROGRAMMER BY ANDROMEDA RESEARCH. thank you
Yeah... i ordered them too! Will see..
Pomona is very sensitive (and expensive) tho...
Thanks cklair!
Using mini probe from Andromeda research,works good.
Hey guys would Pomonoa SOIC8 clip work too ? Or do I need grabbers ?
thx
