This Volvo V50 1.6 HDI PSA engine has FAP problems, tried to remove FAP with ECUSAFE 1.9.3.0, by EDC16 PSA Module and EDC16 Volvo Module.
FAP now seems to be ok (removed), i managed to run with diferential sensor unplugged and no DTC, before i remove it went to safe mode and "Drilled FAP" DTC and no more then 100~120km/h.
BUT NOW, when 135~140km/h are aquired, ESP/ABS light is on, and after that can?t do more 140 Km/h, unless i turn off/turn on ignition even whith car running.
If i stop and aquire 135~140km/h ESP light is on again and after that can?t do more 140 Km/h again.
After ESP/ABS light on, no DTC's are stored on engine ECU, but ESP/ABS ECU got some DTC like "anti-skid system non passive with engine ECU".
I really don?t know if the ESP/ABS problem is related with removing FAP, because before, with FAP activated, the car enters safe and can?t run at 135~140km/h mode.
Could someone please check BDM flashs files and see if there's some error causing ABS/ESP problem? Or remove FAP manually?
