Results 1 to 2 of 2
    lee_hdi's Avatar
    Sheffield
    Default Installing OP-Com problem
    I'm having a problem updating to version 1.39. I received my op-com today and version 1.33 installed fine, but I can't get the activation code for 1.39
    Heres the instruction I got
    Step1: Installing 090820B.
    Step2: op-com cable plug to computer USB connector, it can?t connect to the car
    Step3: open the icon OP-COM090820B on the desktop, click the ?setting? ,select interface type ?op-com REVISION-B?, then click ?save config? ,and return to the main interface, click ?setting? again, then choose and click ?interface test?, after two minute, the hardware will become 1.33 version to 1.39 version .re-open OP-COM and after enter setting to click ?interface test ?,you can view it?s 1.39version .and writting down the serial number
    Step4: from step3 return to main interface of OP-COM, select one by one , Diagnostics---1999---CORSA-B?ENGINE, then select X12XE enter to register interface, please do not close this register window ,and following setp5.
    Step5.Estract file WINHEX, and installing WHXSETUP.exe. then open the WINHEX which just Extract opening, click and open winhex.exe. select menu TOOLS, click OPEN RAM, in the display window , select and click OP-COM, then click the Primary memory , and appear a small window ,then click OK enter in main interface of winhex, click the menu ?SEARCH?, select and click the following menu ?FIND TEXT?, a dialog box will be appear , please fill the serial number into on the top of dialog box ,then click ?OK?, and press F3 on the computer keyboard , from the WINHEX main interface to find and remember a code 8-3,like this :BEA2C2A-4C1,and click please click menu ?search? from winhex main interface again ,select ?FIND TEXT?, a dialog box will appear ,then write the front eight number of 8-3code into this dialog box ,after click OK, then find a 8-8code from on the right of winhex main interface ,such as BEA2C2A2-4C1EZ2CA,please write down this 8-8code ,and fill into the OP-COM register window ,click ACTIVET , and the update is success .
    Having a bit of trouble when it comes to step 5.
    Here's my serial number
    So I do the search text for the serial number "C5EEK3VU"
    Click OK and get this....
    Press F3 and get this....
    so where's the code?
    lee_hdi's Avatar
    Sheffield
    Sorted it. Downloaded the firewire from somewhere else and also updared the software
    No passwords or activation needed
