Results 1 to 12 of 12
    Default Peugeot Autoliv ECU
    Hi, I ve got an Airbag ECU from a costumer but carprog doesn?t suport the ECU. The ECU is an Autoliv 619 90 78 00 9673393680 04/06/10 I could find 2 EEProm with the following references: 1-(S25A32 DADVK3 8080) 2-(MUAC LMC60 35IM) and an MCU AUtoliv 619401700A 1019KE403 P30
    Could you tell me what EEprom I need to read to clear crash data??
    credoline's Avatar
    Србија
    1-(S25A32 DADVK3 8080) supose to be 25320 eeprom, check pin 4 must be on GND.
    Ok Thanks I will try it and I?ll report.
    I?ve read as it was 95320 hope it?s ok, now I need someone that helps me to clear the crash data,
    THANKS
    morfej's Avatar
    Should be fine. Tested on similar.
    Br
    Default Partner autoliv <611019900-9673576980
    Please I need crash reset for this car If some one have i would be very happy.
    Quote Originally Posted by morfej View Post
    Br
    Newbie autotec's Avatar
    Jul 2011
    Hey it is my crasch dump, please clear my file
    einet's Avatar
    This post is to confuse!
    What car what model from airbag unit?
    post correct info!
    Jul 2011
    Sorry, to many work and short time.
    Citroen Berlingo, 2010 year, Ecu Autolive 611 01 99 00, and psa no: 9665558380.
    please.
    Newbie emiliopro's Avatar
    Oct 2017
    France
    Thumbs up Hello
    This file is Okay not fault...
    AutoPower Performance CHIPtuning/ECOtuning/DSGtuning
    100%tested DPF EGR ADBLUE LAMBDA TVA VSA EVAP CAT DTC errors delete
    Professional chip tuning development
    Car, Bike, Agriculture, Bus, Truck, Marine
    Oct 2017
    France
    Post p30esteves
    P30R5C2B9_D V89
    dimet's Avatar
    MKD
    Quote Originally Posted by emiliopro View Post
    P30R5C2B9_D V89
    Password please
