Results 1 to 7 of 7
    Feb 2011
    Default peugeot 206 1,9 diesel 2000
    having trouble with my airbag light is not coming on when i turn my ignition on i have checked fuses i have checked and changed the bulb in the clocks still no luck with it so i changed the clocks 4 a new set just to try out and i still have no airbag light i dont know where to go from here and i dont even know if my airbag will still be working without having the light
    credoline's Avatar
    Србија
    check power suplly to airbag unit pins (+12V and GND) and make a diagnose to airbag
    Feb 2011
    how do i do this
    Feb 2011
    whats the best way to check this
    electromech's Avatar
    Behind a large rock
    Quote Originally Posted by nitehawk10 View Post
    M8 very important ......Judging from you last two post you not use to checking power at a module.... rather take your car somewhere to have it checked as a set of airbags and teeth are very expensive(you could set off all your airbags if you check the wrong wires)
    Feb 2011
    its strainger cos i just cannot get the light to work could it be the plug in the back of the airbag on the steering wheel
    Feb 2011
    thats the only thing i have changed plus the airbag
