Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    DK Veteran dj_piex's Avatar
    Italy
    Default immo-off sagem safir2 clio 1.2
    I friends,Today I had a immo-off of a sagem Safir 2 clio 1.2,on
    DK I downloaded the program that sends the signal for use with Interface max232, tells me to connect the foot 23 of the 27C512, but is a ground ...
    is not that the right foot 22?
    does this procedure? someone has already tried?
    thanks.
  2. The Following User Says Thank You to dj_piex For This Useful Post:
    rumensivanov (1st September, 2021)
  3. #2
    rabbitepp's Avatar
    Feb 2011
    1.pin 37 - cut from ecu
    2.conect ecu to car
    3.ignition on
    4.in 27c512 memory pin 22 circuit a few to tens times to ground
    5.immo removed
  4. The Following 7 Users Say Thank You to rabbitepp For This Useful Post:
    dantetimoc (28th November, 2019), hepike (8th July, 2020), nikolakismb (17th October, 2024), rumensivanov (1st September, 2021), tepSIJA (3rd April, 2021), yasser (13th August, 2023), Yhoni (8th February, 2021)
  5. #3
    Italy
    then I do not have to use the max232?
    just put to the ground pin 22?
  6. #4
    rabbitepp's Avatar
    Feb 2011
    yes a few to tens times but careful to not circuit other, pin 37 must be cut from ecu, 100% solution tested and worked
    Italy
    ok, thank you, tomorrow I'll try '..
    but then tell me one thing, what is the frequency generator with all the circuits that are out there, if he 's so simple?
  8. #6
    rabbitepp's Avatar
    Feb 2011
    i use this method few years and worked, try
  9. #7
  10. #8
    kokkinos panos's Avatar
    GREECE
    hello,
    does this procedure work with fenix5 also?thank you!
  11. #9
    Italy
    i don't have never tryed on fenix5, only safir2
  12. #10
    luis12's Avatar
    Jan 2011
    Panama
    Default Sirius32, dude
    Quote Originally Posted by ecuprog View Post
    Hi friend, Im triying to use an recicled Renault Sirius32, on a different car, but dealer says its impossible to unlock it, I removed a M29F200 memory read and dumped, but its very hard to remove. Can I program it without remove from the ECU? or do you know other method to remove inmo. Thanks in advance.
  13. #11
    luis12's Avatar
    Jan 2011
    Panama
    Hi Ecuprog, tell me: the pin I need to remove in Safir for Inmmo off is 37 on the ECU connector?
  14. #12
    rabbitepp's Avatar
    Feb 2011
    yes cut 37 in ecu conector
    but circuit 22pin in tms pin not ecu
  15. #13
    South Africa
    Quote Originally Posted by luis12 View Post
    search this forum many working solutions for sirius32
  16. #14
    dear all,
    I am with problems with a SAFIR2 ecu.
    I saw the procedure of ecuprog but i have one doubt. What is pin37 of the ecu since there is only 35 pins on the ecu conector.
    waiting for all your help.
    Regards,
    cucaracha
  17. The Following User Says Thank You to cucaracha For This Useful Post:
    fareed1302 (5th March, 2014)
  18. #15
    any help
    regards,
    cucaracha
