Page 23 of 28 FirstFirst ... 131819202122232425262728 LastLast
Results 331 to 345 of 412
  1. #331
    Nov 2011
    thanks guys i hav downl pli image and i am going to do that
  2. #332
    satsmo's Avatar
    Jun 2008
    Just remember to stay away from CCcam as the non standard ecm lengths for TNT stop it from working. So use Oscam and dvbapi as said with the three AES keys. (Please do not post the keys on the forum).
    Hypercam 2.15 will also work with your card. Have you got an old Via 3.0 version or later version?
    I refuse to answer that question on the grounds that I don't know the answer. - Douglas Adams
  3. #333
    Nov 2011
    hej yes satsmos I hav got a viaccess 3.0 version TNT FRENCE yes i would like to tray with hypercam but i don?t thing they made hyper1.15for dm 7000
  4. #334
    Apr 2009
    oscam with dvbapi
    for TNTsat
    just put the AESKeys in oscam server
    oscam conf
    [global]
    nice = -1
    WaitForCards = 1
    ClientTimeout = 5
    CacheDelay = 120
    saveinithistory = 1
    PreferLocalCards = 1
    [webif]
    httpport = 16002
    httpuser = faridbou
    httppwd = faridbou
    httprefresh = 10
    httpallowed = 127.0.0.1,10.0.0.2-10.0.0.99,192.168.0.2-192.168.0.100,192.168.1.2-192.168.1.100,192.168.2.2-192.168.2.100
    [dvbapi]
    enabled = 1
    au = 1
    boxtype = dreambox
    user = user1
    oscam server
    [reader]
    Label = tntsat
    Protocol = internal
    Device = /dev/sci0
    detect = CD
    emmcache = 1,3,2
    Group = 1
    caid = 0500
    AESKeys = 0500@030B00:PUT-THE-AESKeys-HERE
    oscam user
    [account]
    user = user1
    pwd = anypass
    group = 1
    caid = 0500
    au = tntsat
  5. #335
    DK Veteran Rodbouy's Avatar
    Quote Originally Posted by satsmo View Post
    Use Oscam and dvapi do not use CCcam for TNTsat.
    We can do Oscam here Rod
    Of course we can
    Just showing him the daily builds so he doesn't get too lost.
  6. #336
    Nov 2011
    hej Davvo :
    is it because Iam using Cccam2.1.3/Oscam1.00 are making problem for me ? or I am the only one not getting thinks here not right.
    I will keep trayin in tll it work .
    I trayit pli image it is litle bit complex for me right now
    Ihave put the aes key in the right place ,
    thanks guys for giving me a hope but stil nor working ad the TNT card expired in dec2012
  7. #337
    Mate, The CCcam side of it is for sharing. As of right now thats not your problem.
    You need to focus on reading the card.
    Did you install PLi Jade 3 ?
    Did you manually install oscam (not from the downloads section with the image?
  8. #338
    Nov 2011
    Yes Rodbouy have donwlaod oscam and put it manualy
    pli image doest not have oscam ,I had to donwlaod oscam and put it manualy from oscam page
    thakns
  9. #339
    DK Veteran garry1312's Avatar
    Oct 2010
    Scotland/ Somerset
    Another couple of questions guys.
    How can I access my Oscam Web interface remoteley for instance when at work or out?
    Do use know any crond manager plugins that will allow me to restart oscam or receiver every 24 hours?
    Rest In Peace Michael Mcharg, A true friend and although gone never forgotten. 11-10-08.
  10. #340
    You just set the up range in oscam.conf but I woukd stronlgy advise against it. Also open.port on the router.
    Don't worry about re starting oscam mate, no need. It will tell you if it needs re started. Just let it run
  11. #341
    Oct 2010
    Scotland/ Somerset
    Quote Originally Posted by Rodbouy View Post
    Was this for me and if so whats the up range and what is this for remoteley connecting to server or restarting oscam every 24 hours.
  12. #342
    Both mate.
    I would stear clear of allowing outside connections to the oscam webif.
    If anything open up port 80 on your router for your box up and make sure you have the web if of the box password protected then a simple reboot will reset oscam most of the time
    And no need to restart oscam unless your having problems
  13. #343
    Apr 2009
    @garry
    this is a post from the oscam forum
    You need to have a dyndns for the outside machine and one for the oscam machine.The dyndns of the outside machine must be mentioned in the webif section of the oscam config like this:
    [webif]
    httpport = 6250
    httpuser = user
    httppwd = pass
    httprefresh = 10
    httpallowed = 127.0.0.1,192.168.1.1-192.168.1.254
    httpdyndns = dyndns of outside machine
    of course on you router you must redirect the port 6250 (the one used in the exemple; it may be changed) to the machine with oscam.
  14. #344
    Oct 2010
    Scotland/ Somerset
    No other way around it, what im thinking is what if I am away on holiday and it needs restarted, there would be no way of doing so unless I could access the webif.
    Woke up this morning Mrs turned on the receiver and oscam was not reading the card so had to restart Oscam.
    Been told by some that it is best to restart Oscam about every 24 hours to keep it running smoothly. Know I can do this manually but would rather be able to set a time on it.
  15. #345
    every 24hrs is way to much over kill.
    I have been running OScam for some time now and ONLY ever restart if I have problem.
    If your having to restart every 24hrs then some is wrong.
    I would recommend running the card from a 500s too, much more reliable for a single card setup up.
    You can restart the cardserver from the remote control function of the the box webif.
    By allowing more outside connections direct to the control of OScam is only opening up more possible pitfalls.
