Page 5 of 28 FirstFirst 1234567891015 ... LastLast
Results 61 to 75 of 412
  1. #61
    Apr 2009
    Quote Originally Posted by thered View Post
    cheers m8 just to confirm it is the server not myself who needs to change it then?
    yeah the server needs to change to oscam
  2. #62
    Apr 2009
    Quote Originally Posted by u.s View Post
    upgrade to the latest oscam.ppc
    Multiupload.com - upload your files to multiple file hosting sites!
    i can confirm that you do not need boxkey for your sly card
    yeah your right
    upgraded to the latest oscam
    no boxkey needed
    im still learning about oscam
    All the latest versions of OScam do NOT need the 0963 BoxID in the oscam.server file.
    OScam now reads the boxid directly from the card during start-up.
  3. #63
    Apr 2009
    @thered
    the old blue yellow house sly card
    the caid is 0961
    the new white cards are caid 0963
    thats why they dont work
  4. #64
    V.I.P. Member thered's Avatar
    Aug 2008
    Quote Originally Posted by davvo View Post
    @thered
    the caid is 0961
    well the cards dead basically anyway but from what you are saying if i wanted to use my dead card i could just change the oscam configuration to 0961 and it would work
  5. #65
    Apr 2009
    sly just 0963
    you can try 0961
    all 3 files need editing restart oscam
    whether it works on picktv ??
  6. #66
    Aug 2008
    no is the answer
    im not sure but didnt pick tv used to be sky 3 because it used to clear that
  7. #67
    Apr 2009
    how long ago
  8. #68
    V.I.P. Member father ted's Avatar
    Feb 2008
    scotland
    silly question but does oscam auto-update your card?????
  9. #69
    Apr 2009
    Quote Originally Posted by father ted View Post
    AU over CCcam
    Many people still use CCcam as client, but unfortunately AU will not work with the CCcam protocol. For AU to work, you should set up OScam and CCcam to use CAMD3 protocol, with an L line in CCcam.cfg. The following is an example of two S02 cards which are updated by a CCcam client through the NewCamd protocol (N Line).
    HD+
    Unfortunately, OSCam cannot update an HD+ card with a CCcam client, neither by NewCamd, nor by Camd3 protocols. If the server also runs a CCcam server, you can use it as a workaround.
    "Direct connection" NOT OK:
    CCcam client connected to OScam server through N-line or L-line.
    "Indirect" OK:
    CCcam client through C-line to CCcam server and CCcam server through N-Line to OSCam
    e
  10. #70
    Sep 2010
    no is the answer
    to answer your question no a old yellow house card ( caid 0961 ) will not work. sky terminated all of these cards once the rollout of the new white ( caid 0963 ) cards had been completed.
  11. #71
    Sep 2008
    whats the current state of play with pick tv
    is cccam not clearing but oscam is
    any other channels sly have implemented this anti cs measures.
  12. #72
    Apr 2009
    Quote Originally Posted by jfish View Post
    oscam reads card and clears pick tv then can pass to other cams
    cccam newcs or any other cam not clearing pick tv as card readers
    other channels with anti cs measures
    dont think so YET
    sly sports 1234 and sly 1 and 2 on same transponders
    as pick tv and picktv +1
  13. #73
    slick_dick's Avatar
    Essex
    Thumbs up Whats the deal with oscam+cccam2.1.3 once installed??
    Thanking you
  14. #74
    Apr 2009
    keep your original cccam 2.1.3 config
    and add the N line to your cccam cfg
    the N line is on page 2 on this thread
  15. #75
    slick_dick's Avatar
    Essex
    Awesome just what I wanted to hear,
    davvo
