Results 1 to 14 of 14
    Default How to read/write E39 M62 ME5.2 ecu?
    I want to read the image for chiptuning purposes and i?m searching for a tool like KWP2000 or digiflasher which supports the Bosch ecu 0261203474. Some tools can read other ecus with cc460 but i never found a flasher that can work with these ecu.
    With GT1/SSS i can program the stock data but i want to write a modified map.
    Or is there any other possibility to work with this ecu?
    Kind regards
    SP
    Top Poster grimmer's Avatar
    Dec 2010
    norfolk uk
    what engine is the m62 and what year?
    okay, some more details
    BMW E39 540i
    year 01/1997
    M62B44
    ME 5.2
    Bosch 0261203474
    Byteshooter, MPPS, Frieling... think there are a lot of tools that can read/write M5.2 from BMW
    Quote Originally Posted by exe123 View Post
    Byteshooter is too expensive for private use.
    I?m not quite sure if MPPS will work.
    The device list includes the E39 4,4 V8 M5.2 but the CC460 needs a programming voltage of 16V and i cant see any programming voltage on OBD-socket.
    The 20 pin diagnosis socket provides a Programming voltage input and when GT1 is programming this ecu, i can measure the 16Volts on this line. When i disconnect this wire it?s not possible to programm the ecu with. In conclusion, the programming voltage is needed.
    Does anyone have a pin assignment for the MPPS interface? I want to know if this interface provides a programming voltage pin as well. If yes i can make a custom interface to connect the requied wires.
    Can anybody confirm that the programming of a CC460-ecu will work with MPPS?
    Thanks for your help.
    SP
    Oct 2013
    SP, did you manage to read the CC460? And what programmer did you use? I'm in the same situation and need immo off
    Oct 2011
    MPPS will work,i am pretty sure...i done a few dde3.0 k line but i am not 100% sure for m5.2,but mpps is very chep so try,there is that option...
    Oct 2013
    Ivan. you're right MPPS is super cheap. I just ordered one and should have it in a few days. thanks for the tip!
    This is from a 97 318i and original DME is missing. I'm trying to flash a bosch 0 261 203 668 with immo off.
    Also, I only have the modules and no car. So hopefully I can powerup the DME and do it on the bench ok.
    Hi people, sorry for bumping an old thread. Does MPPS read full flash of this ECU, or just 32kB like Galletto does? I only need to get ISN out of this unit because I ran into trouble with reading the EWS and my AK90 emptied the data of the 2D47J MCU. I am trying to save the EWS before ordering a new one from the dealer's.
    HeXeN's Avatar
    Mar 2015
    MPPS tried and cannot read this ecu, only ID, but kess read only 128kb of me5.2.1 and with this data you cannot extract ISN, you need full 256kb read.
    mexanico1971's Avatar
    portugal
    Any one knows how to disable speed limit in this ecu ?
    Thank"s in advance
    BRS
    My work is my life ART TECH GARAGE
    May 2017
    No bid deal there is vmax limiter inside the code.
    In 474 search for 1C 90 20 99 34 C8, C8 is vmax. max soft codes limiter is (if i remember correct) 310km/h but there are several more limiters to pretend vmax like temperature limiters...
  13. The Following 2 Users Say Thank You to Lambda1 For This Useful Post:
    jl01152 (10th May, 2022), mexanico1971 (17th April, 2020)
  14. #13
    Aug 2016
    Hello everyone. Once you have the cc460 binary file how to delete the EWS? It is for a BMW M44 engine with ecu m5.2.Thanks in advance
  15. #14
    Aug 2016
    Hello everyone. Once you have the cc460 binary file how to delete the EWS? It is for a BMW M44 engine with ecu m5.2.Thanks in advanceHello everyone. Once you have the cc460 binary file how to delete the EWS? It is for a BMW M44 engine with ecu m5.2.Thanks in advance
