Results 1 to 4 of 4
    Turkish
    Default Is possible inmo off Golf IV 1.6 Magneti Marelli IAW4MV.?
    Is Possible inmo off for VW Golf IV 1.6 Magneti Marelli IAW4MV ?
    Has anybody ever gotten?
    i have read for flash 29F400 and eeprom 95080.
    Hungary, Mosonmagyar?v
    Hi!
    Wath is problem with ecu,on this model easy the ecu swapping.See this:
    Immobilizer III ECU Swapping - Ross-Tech Wiki
    DK Veteran VTS_Tibi's Avatar
    no, it is not possible!
    I just finished a VW Bora 1.6 16V IAW4MV today with immo problem.
    Please write down what's the problem with the car and I hope I will be able to help you
    btw.: read my thread here:
    http://www.digital-kaos.co.uk/forums...roblem-198239/
    yeah, if the dump is corrupted, just load a new dump into the 95080 - all IAW4MV dumps will be OK
    then do the steps written down at the VAG-com site:
    1.
    [Select] -> [01 - Engine] -> [Login - 11]
    For the following procedure, use the PIN of the NEW(USED) ECU.
    2.
    [OK] -> VAG-COM will validate the data you have entered and return you to the Login screen, where the Login Code will show as "XXXXX".
    [Do it!]
    3.
    [Adaptation - 10] -> Enter 050 in "Channel Number" -> [Read]
    For the following procedure, use the PIN of the OLD (ORIGINAL) ECU.
    4.
    [Save] -> [Done, Go Back] -> [Close Controller, Go Back - 06]
    5.
    Switch OFF the ignition and let the car sit for ~1 minute, then switch ON the ignition again.
    6.
    Verify that the NEW (USED) ECU now shows the VIN and if supported IMMO-ID of the vehicle now.
    you'll need both the new dump's pin and the old dump's pin - which was in the car - today I've tried with the 4 digit PIN, and it was not successful, but with the 7 digit PIN it did without a problem
    you can easily make a 7 digit pin from a 4 digit pin with this programme:
    http://www.digital-kaos.co.uk/forums...onvert-169374/
