Results 1 to 13 of 13
Thread: ST27C512
    maaxxyy's Avatar
    North Pole
    Default ST27C512
    Hi guys, i'm trying to read the above eprom ST M27C512 using DIP32-PLCC32 adapter, but read is showing blank. I'm using willem GQ-3X programmer, i also have x-prog and upa. If anyone could give me pointers, i would be really grateful. Thanks
    miha99's Avatar
    EU
    GQ-3X programmer with DIP32-PLCC32 adapter must read this flash, be shure to have a good contact in adapter with flash !!!
    BIH
    probably bad contacts
    PierreTheron's Avatar
    Centurion,South Africa
    Quote Originally Posted by pajo View Post
    Bad contacts .. Thats correct .. Try to put a 2mm piece off plastic liner underneat the chip or improvise till you get good contact..
    My pint of thought.
    Cheers Beers
    DK Veteran elchip's Avatar
    EU
    Quote Originally Posted by PierreTheron View Post
    My pint of thought.
    Cheers Beers
    Yes many time PLCC socket is to deep maked as bad copy of original socked and chip go to many down.
    You have right 1000%.
    Best regard's
    [I]Automotive Electronics Solutions
    Mercedes-Benz Reverse Development Engineer ...
    Mercedes CFF 2010-2017 CFF all models all modules
    Vediamo help flashing over teamviewer ...
    JLR SDD online + offline ...last official ...
    Dont know that if there is a SW update for pin configuration for 27Cxxx of PLCC32 package. And this as normally does to many universal programmer for 27Cxxx PLCC32, willem GQ-3X also, needs DIP28-PLCC32 adapter and not DIP32-PLCC32.
    maaxxyy's Avatar
    North Pole
    Thanks for your comments guys, is everyone sure on the adapter dip28 and not dip32?
    racin-snake's Avatar
    Jun 2009
    xprog adapter mate and try giving the contacts on the chip a bit of a clean with a bit of wet or dry or as i use the wifes emery board
    make sure its clean
    it also helps the soldering back
    straight forward with xprog adapter
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
    maaxxyy's Avatar
    North Pole
    Heres a pic of the eprom and adapter, but i will look at xprog.
    maaxxyy's Avatar
    North Pole
    Still having trouble with this eprom, i cant see anything on x-prog to read it???
    DK Veteran foxdata's Avatar
    IRAQ
    hi mate
    i have plcc32 to dip32 adapter but it not have any component on it
    i think your problem in your adapter type
    maaxxyy's Avatar
    North Pole
    Looks like i need the dip32-dip28 adapter then??
  13. #13
    maaxxyy's Avatar
    North Pole
    All sorted, just had in the new adapter dip28-plcc32. Thanks for your help guys
